"Operation cannot be performed with units" for exponential function
"Operation cannot be performed with units" for exponential function - Сообщения
#1 Опубликовано: 25.06.2023 14:26:10
EngMath
EngMath
0 сообщений из 51 понравились пользователям.
I get the "Operation cannot be performed with units" error for a complicated equation involving exponential functions which seem to be the culprit:
Here's the file:
Operation units.sm (17,06 КиБ) скачан 1508 раз(а).
Is there a mistake in this equation in SMath ? Here's what it looks like in the original:
#2 Опубликовано: 25.06.2023 15:31:07
The main error you made is in obtaining the pulsation from the frequency.
Also in the formulation of X5 there were two or three errors of evaluation of the SIN (or cos) of the pulsation multiplied by a time (attention to the use of parenthesis)
Operation_units.sm (17,45 КиБ) скачан 1454 раз(а).
#3 Опубликовано: 25.06.2023 16:23:53
EngMath
EngMath
Thank you very much. The formula for ω_n from the book did look suspicious to me so I tried removing f_n from it but it didn't help so I thought that the main problem lies somewhere else.
#4 Опубликовано: 26.06.2023 06:13:35
That's a strange hybrid; the equations should be the following:
#5 Опубликовано: 26.06.2023 11:09:04
EngMath
EngMath
How can I plot the result as x(t) for t=0 to t=12 s ? From what I remember, plots require x as a variable so I tried with u(x) but I still can't make it work even with all the occurrences of t replaced with x (although I'd rather avoid doing that):
Operation units fixed with plot.sm (16,57 КиБ) скачан 1449 раз(а).
#6 Опубликовано: 26.06.2023 11:41:54
You have to manage the variable [x] and the result [f(x)] units
2023-06-26 16_39_37-SMath Solver - [Operation units fixed with plot.sm_].png
