for loop programing issues
for loop programing issues - Сообщения
#1 Опубликовано: 10.09.2021 02:02:33
wty3000
wty3000
a very simply question.
The result should be that the statements s+jj are executed 100 times, jj is incresed by 1.0 each time
Finally, s is the sum, and the result should be a number such as 5050.
I use this example to verify the execution of the for loop
so what is wrong with it ?
forloop.sm (3,04 КиБ) скачан 1211 раз(а).
#2 Опубликовано: 10.09.2021 10:02:27
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
It works well for me
#3 Опубликовано: 10.09.2021 10:10:00
Fine here too, no problems.
Is the Auto calculation enabled?
#4 Опубликовано: 15.09.2021 00:30:44
wty3000
wty3000
after the software restarted, the for loop is OK
thanks
#5 Опубликовано: 15.09.2021 08:43:49
#6 Опубликовано: 15.09.2021 14:29:04
thanks
So it was "four engineer joke" again.
