Snippets definition
Snippets definition - Snippets need to be saved in the correct folder to work - Сообщения
#1 Опубликовано: 05.10.2021 09:56:43
pisker
pisker
1 сообщений из 1 понравились пользователям.
Snippets cannot be saved in an arbitrary folder and later moved to the correct location.
Correct locations:
/AppData/Local/Programs/SMath Studio/snippets
OR
/AppData/Roaming/SMath/extensions/snippets
OR (if installed for all users)
If a snippet has to be made from an existing file, generate a new file, copy the relevant parts, edit the file properties and save it directly in the correct location. A simple copy of a file to the correct location is not working.
⚜ Kenny Lemens, P.E. ᵂᴵ 01.12.2022 10:41:00
