links: Worksheet domain doesn't change
links: Worksheet domain doesn't change - Сообщения
#1 Опубликовано: 08.06.2013 17:58:27
BTW I've found a similar issue using links (like those in SMath Reference Book): a link show you another sheet but the domain still remain the same, so if you save a change in a 2nd document you overwrite the 1st, not the 2nd!!!
That's an issue that I've noticed some time ago and that could be very dangerous.
best regards,
w3b5urf3r
#2 Опубликовано: 08.06.2013 18:14:35
Группа: Super Administrator
Thank you! Fixed.
Regards.
Martin Kraska 08.06.2013 18:34:00, Davide Carpi 09.06.2013 03:04:00
