Exponential expression bug?
Exponential expression bug? - Сообщения
#1 Опубликовано: 20.08.2009 16:51:18
qev
qev
Hi! I'm new to using SMath, and I've run into what might be a glitch.
This: [math]f(x):=x*10^-15[/math] won't calculate, giving an error "1E - not defined" for any value of x. Is this just a precision problem with variables in the program?
#2 Опубликовано: 20.08.2009 18:09:07
Hello qev,
It seems it is corrected. This is from the SMath Live:
[LIVE width=216 height=257]http://smath.info/live/?file=590[/LIVE]
This is obtained from SMath-Live, inserting some expressions and copying the link from there into this post ("quote" this message and you will see it)
Play with it.
P.S. Pay attention on your Regional settings (see the posts about it). What is the decimal separator (point or comma) and what is the function argument separator (comma or semicolumn)
#3 Опубликовано: 20.08.2009 22:39:51
2 335 сообщений из 4 031 понравились пользователям.
Группа: Super Administrator
I remember this error. It was some time ago and it is fixed now. I just don't remember in what version it was fixed... so, if you are using the latest SMath Studio 0.82, then, please, tell me what version you need (Desktop/DesktopPortable/DesktopLinux/Handheld) and I will create fixed setup files for you.
Best regards, Andrey Ivashov.
#4 Опубликовано: 21.08.2009 06:14:18
qev
qev
Oops, I should have mentioned what version I was using in my original post.
I'm using the Desktop version 0.82 build 3477, on WinXP SP3.
Thank you!
#5 Опубликовано: 21.08.2009 19:44:19
Sorry for waiting. Here is fixed versions:
SMathStudioDesktop.0_82_3520.Setup.msi (Standard Setup)
SMathStudioDesktop.0_82_3520.Portable.exe (Portable version)
BTW, this is pre-release version
#6 Опубликовано: 26.08.2009 02:44:01
qev
qev
It works great! Thank you.
