Wrong unit for (variable with units)^number
Wrong unit for (variable with units)^number - Сообщения
#1 Опубликовано: 20.05.2023 02:50:55
JP
JP
I have:
x=number (inches)
A=x^-number
A= decimal number.fraction (unit)
Why am I getting a results that is a product of decimal and fraction rather than a decimal or fraction?
The unit seems to be only for the fraction.
I am not sure how to paste my results from SMath Studio.
#2 Опубликовано: 20.05.2023 03:06:10
Valery Ochkov
Valery Ochkov
67 сообщений из 716 понравились пользователям.
I have:
x=number (inches)
A=x^-number
#3 Опубликовано: 20.05.2023 04:11:14
I have:
x=number (inches)
A=x^-number
A= decimal number. Fraction (unit)
Why am I getting a results that is a product of decimal and fraction rather than a decimal or fraction? ...
Because that's the correct answer:
... The unit seems to be only for the fraction. ...
Powering units could be some confuse, but don't worry, more confusing could be check the SI official standard about how to write it.
#4 Опубликовано: 20.05.2023 10:01:30
JP
JP
How do I ignore the units for x=7 in when used in the A=x^2 formula?
I tried 'ignore units' and it did not change anything.
Thanks!
#5 Опубликовано: 20.05.2023 12:20:31
How do I ignore the units for x:=7
Type 7 ... multiply ... type ' [apostrophe]
In the round place holder ... Units inch
#6 Опубликовано: 20.05.2023 14:26:15
Originally Posted by: Jean Giraud [url=/forum/yaf_postsm81315_Wrong-unit-for--variable-with-units-number.aspx#post81315][/url]Type 7 ... multiply ... type ' [apostrophe]
Does it work as you demanded ?
#7 Опубликовано: 20.05.2023 15:02:47
Never do this, Razonar's approach is the correct one.
Jean is simply against SI units, don't listen to him for anything involved units.
And never ever use Jean's engineering calculations for anything.
They are notorious for being wrong and giving false results.
If he insists at anytime about using SMath 0.99.6179, simply ignore it.
That is a 6+ year old version of SMath, always use latest stable.
Alvaro 20.05.2023 18:34:00
#8 Опубликовано: 20.05.2023 18:27:54
How do I ignore the units for x=7 in when used in the A=x^2 formula? ...
Hi. Something like this?
#9 Опубликовано: 21.05.2023 17:32:01
JP
JP
@Razonar
Not sure. If I use 'A' in another equation, will it consider the units for A?
I dont what it to as it will mess up the units for that answer...which will mess up the units for the subsequent equation.
#10 Опубликовано: 21.05.2023 19:12:35
The choice as to whether you want to use A with or without units is yours. You can use the version of A with units, or the version of A without units. But not both at the same time.
#11 Опубликовано: 22.05.2023 06:49:46
I have:
x=number (inches)
A=x^-number
Such problems usually emerge if you have an equation where the variables aren't meant to be numerical values of quantities given in a particular unit rather than being real physical quantities (number times unit).
SMath is designed for work with quantity times unit variables. If you want to use an empirical equation, you also must provide the units of each variable (be it input or result).
You can integrate such equations into a world of proper handling of physical quantites by dividing each input parameter by the unit in which it is supposed to be inserted and by multiplying the expression by the unit in which the result is supposed to be given by that empirical model.
Worksheet2.sm (5,34 КиБ) скачан 1402 раз(а).
Alvaro 22.05.2023 11:36:00
#12 Опубликовано: 22.05.2023 11:35:24
... You can integrate such equations into a world of proper handling of physical quantites by dividing each input parameter by the unit in which it is supposed to be inserted and by multiplying the expression by the unit in which the result is supposed to be given by that empirical model.
That is a very smart recommendation.
