sys: same calculation different result
sys: same calculation different result - Сообщения
#1 Опубликовано: 18.04.2020 09:27:08
haweHofmann
haweHofmann
3 сообщений из 32 понравились пользователям.
Copy from one page to an other shows different behavior of sys P
I know that eval will doctor (hello Jean :-) to the same result.
but why is eval necessary in the second case und how can I see if eval is necessary?
#2 Опубликовано: 18.04.2020 10:30:50
Something in there does not cut the mustard.
Attach the creator document to be copied on blank sheet
#3 Опубликовано: 18.04.2020 11:07:02
haweHofmann
haweHofmann
the 2 versions of sys
sys1.sm (23,38 КиБ) скачан 1135 раз(а).
sys2.sm (29,85 КиБ) скачан 1160 раз(а).
#4 Опубликовано: 18.04.2020 12:28:12
Not same α° between the two documents !
Again: too specific rectangular construction of polygon.
They are constructed from vertices coordinates.
That was exemplified few days ago [Area, Perimeter, Centroid]
Arc length on Engineering curve is partial perimeter,
it goes in triplet [A,P,C].
#5 Опубликовано: 18.04.2020 13:11:20
The other conceptual pitfall is your rotation.
rot(,) *[2*2] is commutative for only [2*2] systems [square/rectangle...]
The universal code for XY longer than [2*2] ... XY*rot(,)
If you don't follow this rule, Mathcad red, Smath error ...
#6 Опубликовано: 18.04.2020 16:54:47
From there, you can compute [Area, Perimeter, Centroid]
as per the "Maths Polygon" previously posted.
As well for the native [full/reduced by list]
as for the rotated of any angle.
read NOT commutative
Rotate Gerono.sm (14,28 КиБ) скачан 1158 раз(а).
#7 Опубликовано: 18.04.2020 17:41:53
... complete the tour [A,P,C]
Rotate Gerono.sm (25,09 КиБ) скачан 1154 раз(а).
#8 Опубликовано: 18.04.2020 23:32:56
Difference between two calculation occurs because of numeric and symbolic optimization.
Just right click and select Optimization>Numeric for the copied formula in sys2.sm file
This false flag happens a lot. Nothing is wrong here. As usual, the culprit is optimization.
#9 Опубликовано: 19.04.2020 08:15:53
haweHofmann
haweHofmann
Many thanks to hit the nuke of my question
and many thanks to Jean for pointing out problems which I do not see in my limited perspective.
