Solving Double Complex Integral
Solving Double Complex Integral - Solving Double Complex Integral - Сообщения
#1 Опубликовано: 27.04.2017 13:56:58
Hello "Doctors",
Can't make it work !
Fourier Quantum CoC.sm (72,62 КиБ) скачан 1323 раз(а).
#2 Опубликовано: 27.04.2017 15:00:55
Arie
Arie
I think you want to clear variables x and y before the definition of Phi. That seemed to get result to evaluate for me. It isn't exactly the same value as shown in the Mathcad Snapshot, but its close.
Edit: The other thing you could do is change the variables of integration to something other than x and y.
#3 Опубликовано: 28.04.2017 11:28:37
... thanks collab for helping. I don't catch "Clear(x,y)"
Worst: it must be evaluated !!! Clear(x,y)=1 [Accepted].
One bug remains in 6179: if the function is complex,
CAN NOT use index 'i' ... a minimal setup is now running.
Will report is it stops calculate.
Smath integrator is horribly slow, even at minimal accuracy.
#4 Опубликовано: 28.04.2017 11:37:28
... to be tried: instead of absolute in the "P for loops"
the Matlab code may be more effective. To get the Greek
letters in the forum: copy/paste from the Smath work sheet.
