Uploading latest code into SVN does not update the plugin in the SMath itself
Uploading latest code into SVN does not update the plugin in the SMath itself - Сообщения
#1 Опубликовано: 10.07.2023 11:04:34
muiz
muiz
15 сообщений из 22 понравились пользователям.
Hello everyone,
i recently uploaded the latest version of Maxima plugin code under the MaximaPlugin folder in the SVN (https://smath.com:8443/!/#public/view/head/plugins/MaximaPlugin) and when attempting to download the plugin in the Extension Manager of SMath, I encountered an issue where the new version was not compiled, resulting in the older version being retrieved. Do I need to make any changes after uploading the files to the SVN? Upon reflection, I realized that I did not modify the version of the plugin (as far as I am aware). Could this be a contributing factor to the problem?
Muiz
#2 Опубликовано: 10.07.2023 16:19:17
1 442 сообщений из 2 935 понравились пользователям.
The SVN is like any repository, it saves the sources so you can keep track of the changes (and eventually revert them). If you want to update a plugin you have to compile and release the code.
To do it go to the homepage, on the footer there is a release manager link. Once logged in you can compile the code from the svn (current or a previous version) for any SMath version.
You don't have to be the original author to update any plugin. Also, you can compile a plugin for "alpha testing" if you flag "not approved" (will be available by direct link but won't show in the extensions manager).
muiz 10.07.2023 16:25:00
#3 Опубликовано: 10.07.2023 17:10:59
muiz
muiz
I am not sure if I am doing it right, but I am unable to build the plugin. I used the link https://smath.com:8443/svn/public/plugins/MaximaPlugin for the SVN Path and when I clicked the build button, I recieved the following error:
10-07-2023 23:05:03. Task "build" started by "fakemoses" (192.168.1.22).
10-07-2023 23:05:03. Extracting sources from repository...
10-07-2023 23:05:03. - This SVN server is not supported.
10-07-2023 23:05:03. Task completed.
Thank you in advance
#4 Опубликовано: 10.07.2023 17:49:23
That's a common issue. You have to use this root:
https://smath.info/svn/public/
The one with the port address is something used by the visual SVN to show the fancy front-end.
muiz 10.07.2023 17:52:00
#5 Опубликовано: 11.07.2023 05:29:38
muiz
muiz
I did manage to compile the latest version using the release manager, however when trying to publish the plugin, I got the following message:
"Specified GUID is already reserved by extension of another developer. Please check your account. Otherwise change GUID before upload"
#6 Опубликовано: 11.07.2023 05:53:00
I guess it is some recent change made by Andrey, previously it was possible to publish a plugin made by another author.
I suggest to contact Andrey, pointing out that Martin already knows you are actively working on the project.
I won't suggest to change the guid, since this is more appropriate in case you want to fork the project (having 2 similar plugins at the same time).
#7 Опубликовано: 11.07.2023 09:51:36
1 353 сообщений из 2 266 понравились пользователям.
I confirm that user fakemoses is writing a thesis under my supervision. His task is to improve maintainability and usability of the Maxima plugin, including fixing BTS issues. I am fine with sticking to the existing project and and with publishing the changes as beta (visible in the extension manager).
#8 Опубликовано: 11.07.2023 13:38:42
598 сообщений из 1 379 понравились пользователям.
I would really appreciate if his thesis included Linux Maxima support. :d
