Plugin for reading results from civil eng. FE model
Plugin for reading results from civil eng. FE model - Plugin for reading results from civil eng. FE model - Сообщения
#1 Опубликовано: 24.09.2021 04:49:35
johnnyontheweb
johnnyontheweb
3 сообщений из 26 понравились пользователям.
Hello all,
I wrote a plugin for SMath Studio that was released as open-source here.
I uses API from a free program for structural FE analysis to extract results. By now, reactions, displacements and beam forces are supported. Results are given with proper units of measure.
I found only outdated PDF instructions on what to do for submitting the plugin to SMath online catalog - the site forced me to use "Release Manager" and I don't know how to proceed to request plugin approval (ie. svn path??).
Can anyone give some hints?
thanks in advance
ps.
any suggestion or change on plugin is welcome - see also this post for warning messages if used in .exe file
Arie 24.09.2021 09:05:00, Oscar Campo 28.09.2021 22:36:00, Andrey Ivashov 01.10.2021 17:07:00
#2 Опубликовано: 30.09.2021 12:18:02
johnnyontheweb
johnnyontheweb
Anyone on how to use "Release Manager" or on how to proceed to request plugin approval?
thanks
#3 Опубликовано: 30.09.2021 21:13:17
You need to contact with Andrey. I asked him to help you.
johnnyontheweb 01.10.2021 02:53:00
#4 Опубликовано: 01.10.2021 17:02:37
2 343 сообщений из 4 048 понравились пользователям.
Группа: Super Administrator
Hello, [USERLINK]johnnyontheweb[/USERLINK]
Release Manager works with internal project repository (SVN) only.
Please contact me by e-mail - I will provide a login/pw for you. You will be able to use Release Manager as soon as the code is there.
Best regards and thanks for your work!
johnnyontheweb 06.10.2021 10:14:00
#5 Опубликовано: 06.10.2021 10:13:37
johnnyontheweb
johnnyontheweb
Thanks, I sent you an email a few days ago.
best regards
#6 Опубликовано: 06.10.2021 18:11:31
best regards
Did you receive my answer to you (sent on 2 Oct)?
If not, I will duplicate it in PM here on the forum.
#7 Опубликовано: 07.10.2021 03:02:12
johnnyontheweb
johnnyontheweb
Thanks, now I reveived in PM.
