Little detail in 3D frame
Little detail in 3D frame - Сообщения
#1 Опубликовано: 09.06.2010 16:37:53
Oscar Campo
Oscar Campo
I noted that the x-y-z frame in the 3D plot is not a rigth-handed system, as usual in engineering.
The label of "x axis" must be "y" and viceversa:
Oscar Campo
Davide Carpi 23.03.2013 07:07:00
#2 Опубликовано: 12.06.2010 01:52:59
Greg Locock
Greg Locock
0 сообщений из 53 понравились пользователям.
Grins, well Smath is right if you think the y axis pointing INTO the page.
But yes.
#3 Опубликовано: 12.06.2010 03:11:34
Oscar Campo
Oscar Campo
If Y axis is pointing INTO the page, is not a common view for engineering.
Also if the axis don't have arrow heads, is confusing.
In picture, Y axis is pointing OUTWARDS the page, but the vectorial product X x Y would be Z in OPPOSITE direction that current SMath frame, so, in the right-hand system, (with X pointing OUTWARDS the page), X x Y = Z in the correct direction.
