Mobius Strip
Mobius Strip - Mobius Strip - Сообщения
#1 Опубликовано: 08.06.2017 09:20:52
Not very glorious, the twisted path is observable.
Snippet is too large size to be attached.
A < 5 min visit ... Jean
Rotate Mobius.sm (29,28 КиБ) скачан 1395 раз(а).
#2 Опубликовано: 08.06.2017 15:11:46
алексей
алексей
17 сообщений из 78 понравились пользователям.
Some examples with Mobius Strip (However, in Maple)
http://www.mapleprimes.com/posts/207879-Rolling-Without-Slipping-On-A-Nonorientable
#3 Опубликовано: 08.06.2017 21:36:33
http://www.mapleprimes.c...pping-On-A-Nonorientable
Thanks "Kamarad" for the link. Interesting visit.
The attached has no animation, 100 mesh.
Rotate Mobius Orient.sm (120,89 КиБ) скачан 1342 раз(а).
#4 Опубликовано: 09.06.2017 05:08:12
алексей
алексей
If you have problems with the size of the animation to display in your posts, I can recommend, if you do not know, a small program "Easy GIF Animator". This program is very convenient for demonstrating the animation, because it can reduce the size of the .gif file by several times and even more (without loss of quality).
I, for example, do not have SMath, but sometimes I want to see the result of professional work.
Thank you.
#5 Опубликовано: 11.06.2017 15:42:29
алексей
алексей
Another example. Additional torsion of the Mobius Strip
(The .gif file was almost 6 Mb in size, and after processing with the program "Easy GIF Animator" became almost 55 KB)
https://vk.com/doc242471809_446439002?hash=a24d750a83896a7df8&dl=907bc6a2fa42c96149
#6 Опубликовано: 12.06.2017 09:28:45
Thanks from Russia for the Quick link ... lovely from Maple.
#7 Опубликовано: 12.06.2017 13:24:57
алексей
алексей
Thank you for your kind words.
If it is interesting, here is the place where today the text of the last Maple program (Möbius strip ) appeared.
http://www.mapleprimes.com/posts/207879-Rolling-Without-Slipping-On-A-Nonorientable#comment202478
