EditOverview of Symbolic Expression Evaluations
Full symbolic expression can be stored in
MItem Class. You can operate with instances of this class using standard operators + - * / and it has several methods to make it easy to operate with expressions. Actually,
MItem is very interesting class that was fully designed by Andrey and it has not been used anywhere before. For example: it doesn't support - and / operators at all (meaning it cannot store and work with them), instead of it every part of
MItem Class expression has Boolean fields:
Negative (means -a) and
Inverse (means 1/a). So, you should respect this fact in order to avoid some errors.
EditInterface to be implemented
IPluginMathSymbolicEvaluation interface
EditMethods
SMath.Math.Symbolic.Expression.SimplifyEx(MItem) - Symbolic expression simplification
SMath.Math.Symbolic.Expression.DifferentiateEx(MItem, MItem) - Symbolic differentiation of expression
