Edit
Summary
SMath Project now provides a shared SVN repository for open source plugins for SMath Studio program. This repository contains plugins for SMath Studio developers on par with third-party projects.
Edit
Repository preferences
Url: https://smath.info/svn/public
Permissions: anonymous read access (no login and password needed)
Edit
How to get available sources
1. Download SVN client program: TortoiseSVN.
2. Install it (reboot can be required).
3. Create a folder on your PC where you want to store the sources.
4. Right click on created folder and choose "SVN Checkout..." item from the folders context menu.
5. Fill in text areas into appeared dialog (usually you need to specify only URL of repository) and press OK button.
To get all plugins simply enter https://smath.info/svn/public
To get a specific plugin enter https://smath.info/svn/public/plugins/WizFunctions (for example)
6. Available sources will be downloaded.
Edit
How to upload your sources
Repository is readable for every user, but write permissions you should request on supportatsmathdotinfo if you want to upload you plugin or make improvements for existed ones.
