Snippets
Modified: 2016/05/12 07:22 by w3b5urf3r - Categorized as: English
A snippet is a small container of re-usable code (math, text, regions). Ordinarily, it is intended as an unit to incorporate into larger programming modules.
Snippets in SMath Studio are simple *.sm files that are placed into the special "snippets" folder.
Edit
How to use a snippet
Every snippet can be inserted into the page:
  • using the Dynamic Assistance;
  • pressing TAB will insert snippet inside the collapsed Area Region
  • pressing Shift+TAB will insert just all snippet expressions without Area Region
Dynamic assistance
  • directly from the Snippet Manager of the Tools menu group.
Snippet Manager
In the Snippet Manager it is possible to download snippets made by other users and shared through the Relase Manager; to do this, change the top-right button target from Local storage to Online gallery.
More snippets
The snippets downloaded through the Extensions Manager are stored in the user's folder %APPDATA%\SMath\extensions\snippets
Edit
How to make a snippet
To make a *.sm file a snippet, follow these steps:
  • go in the File > Properties > File attributes menu and setup a Snippet Shortcut;
Snippet Manager
  • save the file in the snippets folder (in Windows 7 this is usually C:\Program Files (x86)\SMath Studio\snippets);
Edit
History
  • SMath 0.90 (Stable): Snippets feature implemented;
  • SMath 0.95.4594 (Stable): all the available snippet's title translations are included to collapsed Area on snippet insert;
  • SMath 0.97.5280 (Nightly build): Fixed inserted snippet layout when collapsed Area Region exists inside Snippet;
Edit
See also
Edit
References
