SMath run error
SMath run error - One home computer cannot run SMath - 消息
#1 已发布: 2016/12/17 05:31:53
nierges
nierges
0个赞,共3个帖子。
I have a laptop at home (win7) that I try for some time now to run SMath. Here is the error:
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: smathstudio_desktop.exe
Problem Signature 02: 0.98.6179.21442
Problem Signature 03: 58400fc6
Problem Signature 04: mscorlib
Problem Signature 05: 2.0.0.0
Problem Signature 06: 4ca2b851
Problem Signature 07: 1b7e
Problem Signature 08: 10
Problem Signature 09: System.IO.FileNotFoundException
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Already try reinstall the program without luck.
However I can run it on a virtual machine (XP) on the same station.
Do you have an idea where the problem comes from?
Thank you.
#2 已发布: 2016/12/17 09:05:26
1,443个赞,共2,936个帖子。
Hello [userlink]nierges[/userlink],
I guess might be a problem with something corrupted in .NET Framework
Try to launch the Microsoft .NET Framework Repair Tool
