Solve with 4 args
Solve with 4 args - Is it a bug? - 消息
#1 已发布: 2026/7/15 07:34:36
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
solve(4).sm (110.53 KiB)已下载 941 次。
#2 已发布: 2026/7/15 11:14:15
1,139个赞,共1,805个帖子。
Hi Valery. It seems that solve doesn't know how to order the interval.
The 6 solutions numerically
And symbolically
solve(4).sm (158.3 KiB)已下载 957 次。
#3 已发布: 2026/7/17 07:17:36
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Thanks, Alvaro
It is one task from the article
https://disk.yandex.ru/i/59sq-AYpKky-3Q
已编辑 2026/7/17 07:28:06
#4 已发布: 2026/7/25 05:40:05
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Do you know the best solution in SMath?
#5 已发布: 2026/7/25 15:50:39
1,139个赞,共1,805个帖子。
Hi Valery. Two ways.
heart area.sm (13.36 KiB)已下载 900 次。
Mathcad 11:
mc11 double int.mcd (4.77 KiB)已下载 910 次。
已编辑 2026/7/25 17:52:57
Valery Ochkov 2026/7/25 18:27:25
#6 已发布: 2026/7/25 19:20:52
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
And what about this. We can create an animation.
已编辑 2026/7/25 19:47:21
#7 已发布: 2026/7/26 02:28:14
1,139个赞,共1,805个帖子。
It's possible, although speed isn't one of SMath's main features. And with so few points, there isn't much accuracy.
heart area.sm (26.99 KiB)已下载 892 次。
Valery Ochkov 2026/7/26 13:14:28
#8 已发布: 2026/7/26 13:40:28
1,558个赞,共1,868个帖子。
I can write a function that returns a set of closed isolines. The area can be calculated from the points on the curve. To construct implicit graphs, a function is used that returns the coordinate sets of the found isolines.
2位用户喜欢此帖子
Valery Ochkov 2026/7/26 14:32:01, Alvaro 2026/7/27 01:20:46
#9 已发布: 2026/7/26 14:36:05
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Вячеслав, привет!
Брось все силы на создание инструментов оптимизации с ограничением типа Given... Minimize/Maximize в Mathcad 15. Этого очень не хватает в SMath.
И Андрей на это настроен.
#10 已发布: 2026/7/27 01:25:09
1,139个赞,共1,805个帖子。
Using Dragilev Method.
Area and Arc Length of an Implicit Planar Closed Curve - Dragilev Method.sm (16.28 KiB)已下载 914 次。
已编辑 2026/7/27 01:33:24
2位用户喜欢此帖子
Valery Ochkov 2026/7/27 06:01:49, Вячеслав Мезенцев 2026/7/27 13:28:37
#11 已发布: 2026/7/27 13:27:20
1,558个赞,共1,868个帖子。
Yes, something like this with the Gaussian area formula.
ioan92 2026/7/28 11:13:51
#12 已发布: 2026/7/28 08:24:46
1,139个赞,共1,805个帖子。
Hi Viacheslav. In that case, I'd like to point out that dividing by the norme (Δ) means the curve is parameterized with respect to arc length, and that if you're going to improve the points using the original function, you must also do so with the parameter variable, which in the program's notation is T. This is because Dragilev's method ultimately obtains the parametric expressions x(t) and y(t) from the implicit function f(x,y) when starting from a point (xo,yo) on the curve.
This is one way to correct the arc length given by T if you choose to improve the curve points, although there must be better methods involving splines for curves in the plane, not just single-valued functions. There are also better approximations for the area enclosed by the curve; the one used here is simply the area defined by a closed polygon.
Area and Arc Length of an Implicit Planar Closed Curve - Dragilev Method.sm (17.78 KiB)已下载 395 次。
已编辑 2026/7/28 08:36:40
Valery Ochkov 2026/7/28 16:17:18
