1页(7条)
Question about CheckBox - 消息
Hello. Important coefficient k=1.25. Sometimes you need to use it, sometimes you don't need to use it.I decided to take CheckBox. Here's what happened未找到文件。
I tried another way. I changed the formula using inactive check (K=0).Result is good with inactive check未找到文件。
But the result bad with active check未找到文件。
Question 1: Why did it happen?
Question 2: When inactive check, k=0.How can do k=1 with inactive check?
WroteQuestion 1: Why did it happen?
Answer 1: It is a long lasted bug/limitation.
SMath Viewer doesn't respect your decimal places in Smath Studio.
I had reported it 6 years ago, maybe it can't be fixable as it is.
https://en.smath.com/forum/yaf_postsm35182_SMath-Studio-0-98-6077--21-August-2016.aspx#post35182
However, you can round your results as you wish.
Answer 2: What I understood from your desire is;
If checkbox is active, then result should be matrix value.
If checkbox is inactive, then result should be 1.
You can do that with an if/else statement.
questions.sm (4.41 KiB)已下载 1272 次。
Davide Carpi 2022/7/17 07:10:00
WroteWroteQuestion 1: Why did it happen?
Great! Thank you very much!!
When adding units, the result has changed. When checkbox is inactive, everything is fine. When checkbox is active, units disappear.
未找到文件。未找到文件。
1. your example
2. Davide Carpi tutorial 8 years ago.
Cheers ... Jean.
Maths checkbox.sm (22.86 KiB)已下载 1285 次。
Maths checkbox DAVIDE.sm (18.66 KiB)已下载 1298 次。
Cheers ... Jean.
1页(7条)
