Truble with Clear()-procedure
Truble with Clear()-procedure - 消息
#1 已发布: 2020/3/23 14:15:47
manolo
manolo
8个赞,共9个帖子。
The following input;
T:=200 K
Clear(T)=1
T=200 K
does not work as expected. Why?
#2 已发布: 2020/3/23 15:51:32
983个赞,共6,866个帖子。
Pretty mystic ?
#3 已发布: 2020/3/23 16:15:15
manolo
manolo
8个赞,共9个帖子。
Thank you, but:
T.1:=200 K
Clear(T.1)=1
T.1=200 K
will not work...
#4 已发布: 2020/3/23 16:53:02
983个赞,共6,866个帖子。
Thank you, but:
T.1:=200 K
Clear(T.1)=1
T.1=200 K
will not work...
Just reproduce the image posted.
#5 已发布: 2020/3/23 17:00:11
Arie
Arie
94个赞,共285个帖子。
Can you post your .sm file?
#6 已发布: 2020/3/23 17:49:58
manolo
manolo
8个赞,共9个帖子。
Blatt1.sm (2.63 KiB)已下载 1176 次。
#7 已发布: 2020/3/23 19:14:44
Arie
Arie
94个赞,共285个帖子。
You've not cleared the right variable.
You entered "Clear(T1)" instead of "Clear(T.1)"
Blatt1.sm (3.01 KiB)已下载 1192 次。
#8 已发布: 2020/3/23 20:42:37
983个赞,共6,866个帖子。
YES: needed. 'T' may represent a previous matrix,
or some otherwise argument ... ?
#9 已发布: 2020/3/24 08:41:52
983个赞,共6,866个帖子。
In this demo: Sym(f(x,y),L,H,N)
is my universal image algo creator, based internally on 'U'
which 'U' is set to '0' from any other existing creation,
whether vector/matrix.
