Units and matrices
Units and matrices - 消息
#1 已发布: 2010/7/14 15:02:00
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
I was curious to see how units would be handled in matrices. So I tried a few things and was suprised how well it worked. See screen shot below.
Great job. Well thought out. Remeber everthing is calculated in SI units but comes out fine in US/Imperial units.
Ed
#2 已发布: 2010/10/24 12:11:53
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
Another advantage of SMath over Mathcad is for matrix elements to have any units and the math is performed correctly. This matrix and multiplication of its elements is not possible in Mathcad.
Ed
#3 已发布: 2012/8/30 02:36:03
ralfsnell
ralfsnell
0个赞,共3个帖子。
How do these US units work?
If I take a simple force in kips multiplied by a moment arm in ft
I get result in J....then when I try to change units to kip ft
by adding kip, I get m kip...then when trying to get to kip ft
I get
kgm^2 kip'ft
________________
(s^2)kip'ft
Following from cut and paste....
el(F,1)*el(A,2)=225.97*{'kg*'m^2}/{'s^2*''kipft}@''kipft
Also, how do you get the units outside the matrix? I can only
put units immediately after the cell values.
Thanks for any responses.
#4 已发布: 2012/8/30 06:58:49
1,443个赞,共2,936个帖子。
Hi ralfsnell,
simply type in the right placeholder
'kip*'ft
regards,
w3b5urf3r
#5 已发布: 2012/8/31 11:04:14
ralfsnell
ralfsnell
0个赞,共3个帖子。
Thank you, was trying not to type but rather use the drop-down to insert units.
It appears the "*" was the missing element to that effort.
Appreciate your input and the attachment.
Hi ralfsnell,
'kip*'ft
regards,
w3b5urf3r
#6 已发布: 2017/1/18 18:45:25
justhumm
justhumm
0个赞,共18个帖子。
When using a matrix with elements of a variety of units, is there a way to control the display of the resulting units (imperial instead of SI units)?
For instance, in the attached image:
k'(1,1) = A(in^2)*E(ksi)/L(in) = kip/inch, but results are in kg/s^2
k'(3,2) = 6 * E(ksi) * I(in^4) / L^2(in^2) = kip, but results are in kg*m/s^2
#7 已发布: 2017/1/18 19:57:29
1,443个赞,共2,936个帖子。
Hello [userlink]justhumm[/userlink],
You can try using
OutputUnitsSystem=Imperial
instead of
OutputUnitsSystem=Metric
in
%APPDATA%\Smath\settings.inf
(it is an experimental feature)
2位用户喜欢此帖子
frapuano 2017/1/19 06:13:00, justhumm 2017/1/18 20:44:00
#8 已发布: 2017/1/18 20:51:58
justhumm
justhumm
0个赞,共18个帖子。
Davide Carpi:
Thanks for the response! It seems to be working.
Wishlist item:
It would be nice to have the ability to switch between feet and inches for the default imperial unit. :-)
#9 已发布: 2017/1/19 09:19:54
1,443个赞,共2,936个帖子。
You're welcome
Wishlist item:
You can join the [SS-1]
#10 已发布: 2022/2/14 18:54:54
Mark R Harris
Mark R Harris
5个赞,共90个帖子。
When using matrices with units the results are given MKS rather than in the input units as shown here:
Units with Matrices
What an I needing to do to show the correct units?
#11 已发布: 2022/2/14 20:46:07
600个赞,共1,381个帖子。
- After you calculate and get the result, click on the expression or move your cursor with keyboard to it (Step 1)
- There should appear a placeholder on the result part, write there your desired output unit (Step 2)
- When you press enter or click outside or just loose the focus for expression, your output shall be in your input units (Step 3)
#12 已发布: 2022/2/14 22:06:05
Mark R Harris
Mark R Harris
5个赞,共90个帖子。
Thank you so much Overload, greatly appreciated.
#13 已发布: 2022/2/14 23:08:20
Mark R Harris
Mark R Harris
5个赞,共90个帖子。
This is getting so close!
I've tried the plus-minus function, but can't get the min or max element values. I suspect this is because the result isn't a maxtrix:
edit by mod: please use the forum attachment feature; images stored outside the domain soon or leater expires or are removed and the topic becomes unreadable. Thank you.
Or it could be my 'PBCAK' (OSI layer-8) problem...
#14 已发布: 2022/2/15 07:47:55
1,443个赞,共2,936个帖子。
That's the cause, yes. You can use sys2mat() function from custom functions plugin or Max()/Min() functions (uppercase M) from the same extension.
#15 已发布: 2022/2/15 15:46:33
Mark R Harris
Mark R Harris
5个赞,共90个帖子。
Greatly appreciated Davide. Thank you.
#16 已发布: 2022/2/16 13:40:53
983个赞,共6,866个帖子。
#17 已发布: 2022/2/16 13:50:49
Mark R Harris
Mark R Harris
5个赞,共90个帖子。
Thank you Jean, that is very elegant. What was the function of the red kOHMS:=1?
#18 已发布: 2022/2/16 13:56:11
983个赞,共6,866个帖子。
min("matrix") - Returns the smallest element of vector or matrix. If any value is complex, returns min(Re(...)) + i*min(Im(...)).
... Exemplified
2D Plot Discontinuous [min(,)].sm (44.8 KiB)已下载 1538 次。
#19 已发布: 2022/2/16 14:28:13
600个赞,共1,381个帖子。
Actually it is not elegant, very primitive method only used by Jean.
He just continues to try to confuse new users.
He make his own units, not compatible with ISO units.
Which is the case here, he assigned a new red colored Ω to 1. (Ω:=1)
That red Ω is not V/A, ask him to divide it to volts. He won't get 1/Amper.
Don't use his methods, them are just bad practices.
2位用户喜欢此帖子
Oscar Campo 2022/3/11 22:52:00, Jason McCool 2022/2/23 18:31:00
#20 已发布: 2022/2/16 15:05:33
600个赞,共1,381个帖子。
Jean's math is unitless crusade is garbage.
We don't only do pure math calculations.
Engineering and science needs units.
As I have said before;
Math is unitless, science/engineering is not.
Jean's "silence unit" crap is useless, confusing.
As it is shown below.
2位用户喜欢此帖子
Oscar Campo 2022/3/11 22:51:00, Jason McCool 2022/2/23 18:30:00
