Plotting Sine fuction
Plotting Sine fuction - 消息
#1 已发布: 2018/5/7 13:44:59
vijaykhatri
vijaykhatri
1个赞,共23个帖子。
Can someone share an example of plotting a basic sine wave as a function of time.
I am running into some difficulties with the graphing part.
Vijay Khatri
#2 已发布: 2018/5/7 14:36:22
Arie
Arie
94个赞,共285个帖子。
Have you had a look at the wiki here: https://smath.info/wiki/Graphs.ashx
Also take a look at the Interactive SMath Handbook put together by Martin. You can find it by going to tools ->Plugins then clicking on Interactive Books in the left panel. I cannot remember if it's installed by default or not. If it's not there you can download it by further clicking on the "Local Storage" button and selecting "Online Gallery" and choosing to install it from there.
#3 已发布: 2018/5/7 22:47:15
vijaykhatri
vijaykhatri
1个赞,共23个帖子。
Thank You
#4 已发布: 2018/5/7 23:28:16
983个赞,共6,866个帖子。
... a bit more.
Utilities Pts Split-in-range [a,b,N].sm (14.17 KiB)已下载 1068 次。
#5 已发布: 2018/5/9 11:21:08
vijaykhatri
vijaykhatri
1个赞,共23个帖子。
Hi All,
I have a question related to the plotting, it miight be very trivial but I can't seem to figure it out. In the attached file, Basic_sine.sm (7.99 KiB)已下载 1218 次。I have used similar approach in MathCad and it works, however in SMath it does not.
Vijay
#6 已发布: 2018/5/9 11:44:36
Arie
Arie
94个赞,共285个帖子。
Looks like you need to multiply omega by the unit 's (This makes the input to the sine function unitless). The standard sin() function doesn't seem to like units. I'm not sure if this is a bug or not. Note that 'deg is actually unit-less (it's simply a scale factor)
Basic_sine[1].sm (8.91 KiB)已下载 1103 次。
Edit: I'm fairly certain it's not a bug. Inputs to trig functions with any format other than radians or degrees is meaningless.
#7 已发布: 2018/5/9 12:46:11
vijaykhatri
vijaykhatri
1个赞,共23个帖子。
Thank you
