MathRegion Critical Error on DEL key action
MathRegion Critical Error on DEL key action - 消息
#1 已发布: 2022/1/13 14:39:53
Igor Skarine
Igor Skarine
14个赞,共97个帖子。
Eventually I have caught a bug that bothered me in a few latest versions of Smath.
critical_bug.sm (3.85 KiB)已下载 1712 次。
Try to delete the first number "4" in front of the ratio.
Step 1: Select it with the cursor.
显示剧透
Step 2: Press "Del", the "4" turns into a black square.
显示剧透
Step 3: Press "Del" once again. SM pops on "Critical error".
显示剧透
Davide Carpi 2022/1/14 04:08:00
#2 已发布: 2022/1/13 18:06:39
Igor Skarine
Igor Skarine
14个赞,共97个帖子。
Jean,
It can't be doctored, it is not a calculation issue.
Smath Studio crashes at the moment you push "DEL" key to delete this number "4" or whatever else there.
#3 已发布: 2022/1/13 19:31:57
churichuro
churichuro
29个赞,共79个帖子。
I confirm the error
#4 已发布: 2022/1/13 22:05:45
1,558个赞,共1,868个帖子。
Confirmed. I also came across it, but I didn't investigate it. SMath Studio 0.99.7921.69.
#5 已发布: 2022/1/14 01:54:58
600个赞,共1,381个帖子。
confirmed under linux.
same behavior.
#6 已发布: 2022/1/14 05:59:07
1,443个赞,共2,936个帖子。
Thank you, confirmed
System.IndexOutOfRangeException: Index out of matrix bounds.
   in SMath.Controls.MathPainter.PrepareForPaint(MathRegion region, PaintContext ctx, Term[] input, MathAnswer answer, Term[] units, Boolean inputDataVisibility, Int32 currentTermIdx, FontInfo font, Boolean focused, Single& middleLine, Single& baseLine)
   in SMath.Controls.MathRegion.(IGraphics , PaintEventOptions )
   in SMath.Controls.MathRegion.OnCommandSend(String value)
   in SMath.Controls.WorksheetEditor.(RegionBase , String )
   in SMath.Controls.WorksheetEditor.InsertManager(String value)
   in SMath.Controls.Worksheet.Insert(String value)
   in SMath.Controls.WorksheetEditor.KeyDown(KeyEventOptions e)
   in SMath.UI.Accessories.DesktopWorksheet.OnKeyDown(KeyEventArgs e)
   in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
   in System.Windows.Forms.Control.WmKeyChar(Message& m)
   in System.Windows.Forms.Control.WndProc(Message& m)
   in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
#7 已发布: 2022/1/14 10:59:14
600个赞,共1,381个帖子。
... end of it !
It didn't surprise me that Jean couldn't understand what the bug is.
Alvaro 2022/1/14 12:39:00
#8 已发布: 2022/1/14 11:32:56
1,558个赞,共1,868个帖子。
Jean, what you're trying to do here is destructive. You prevent users from helping developers improve the program, that is, you bring harm. You don't have to do that. This is not good.
6位用户喜欢此帖子
Oscar Campo 2022/5/17 12:41:00, churichuro 2022/1/14 14:38:00, sergio 2022/1/14 15:05:00, overlord 2022/1/14 11:57:00, Alvaro 2022/1/14 12:39:00, fedeghi 2022/1/14 16:43:00
#9 已发布: 2022/1/14 14:17:41
1,558个赞,共1,868个帖子。
Jean, in the exUSSR there was such a norm as forced rest. People who worked hard were forced to rest in a sanatorium. And their leaders, who allowed this, were punished. I think you need to go to a sanatorium and temporarily stop working here. I don't want to be punished and I can give you a rest.
4位用户喜欢此帖子
NDTM Amarasekera 2022/1/14 22:41:00, fedeghi 2022/1/14 16:43:00, overlord 2022/1/14 14:23:00, Alvaro 2022/1/14 15:55:00
#10 已发布: 2022/1/14 16:04:25
600个赞,共1,381个帖子。
Basically up to SS 6179, Smath is an equation editor
working similar to Mathcad 11 and earlier, including program.
AFAIK, an option for script style [typical Kalkulator ...]
will manage the critical error demo bug.
Is it possible to combine both: part script style & equation editor ?
As well as accommodate both styles in program ?
Cheers ... Jean.
And yet another useless not related post again.
Unbelievable. Wow, just wow.
Such ignorance, such obstinate, such thick head...
I am out of speech right now.
3位用户喜欢此帖子
fedeghi 2022/1/14 16:45:00, NDTM Amarasekera 2022/1/14 22:42:00, Oscar Campo 2022/5/17 12:40:00
#11 已发布: 2022/5/16 12:06:43
Igor Skarine
Igor Skarine
14个赞,共97个帖子。
Unfortunately,
The "Critical Error on Del key action" was not fixed yet in the latest stable version.
Try to delete "g" by using DEL key.
oldbug.sm (2.25 KiB)已下载 1698 次。
#12 已发布: 2022/5/17 20:38:34
2,344个赞,共4,057个帖子。
组: Super Administrator
Ok, will check asap.
Davide Carpi 2022/5/18 04:42:00
#13 已发布: 2022/6/16 20:29:35
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings!
I can also confirm the existence of this issue ( "v0.99.7921.69" ). Upon investigation, I have (2) items:
  1) The program does not actually 'crash', the program is still running. Thus: you can recover from this bug without losing all your work!
      a) To recover from this error:
            1) On the "⨂ Unhandled exception has occurred ... Index was outside the bounds of the array" popup error message, Click on the button: 「Continue」
            2) 'UNDO' your last action, either via the menu bar: 「Edit」 -> 「↻ Undo」 or via keypress 「Ctrl」 + 「Z」
            3) Repeat steps #1 and #2 until you achieve a successful 'undo'.
  2) The elements of this error seem to require a grouping operator (e.g., Absolute Value, Parenthesis, Determinant, Square Root, Matrix) that is paired with a fraction/division operation, prepend this with a multiplication statement and you can duplicate the error. See screen capture below:
Below are a few statements I compiled; performing the double-delete on the integer '6' will throw the same error:
-Kenny Lemens, P.E.
#14 已发布: 2022/6/23 11:31:02
85个赞,共181个帖子。
Greetings,
I found another configuration that can trigger this error; if you declare/evaluate a variable, and then try to multiply that entire set: you get a syntax error. Now if you attempt to correct the statement by using the [DEL] to remove the evaluation, the error gets thrown (as shown below):
The work around would be to use the [Backspace] to delete/correct the equation, or to copy/paste the terms into a new statement without syntax errors.
-Kenny Lemens, P.E.
Davide Carpi 2022/6/23 14:21:00
#15 已发布: 2022/7/22 17:33:42
2,344个赞,共4,057个帖子。
Finally fixed in version 1.0.8238.
3位用户喜欢此帖子
⚜ Kenny Lemens, P.E. ᵂᴵ 2022/7/22 17:41:00, João Felipe Seráfico Melo 2022/7/22 18:02:00, sergio 2022/7/23 05:37:00
#16 已发布: 2023/4/13 10:40:14
salmawisoky
salmawisoky
0个赞,共2个帖子。
Greetings,
I found another configuration that can trigger this error; if you declare/evaluate a variable, and then try to multiply that entire set: you get a syntax error. Now if you attempt to correct the Candy Crush statement by using the [DEL] to remove the evaluation, the error gets thrown (as shown below):
-Kenny Lemens, P.E.
I tried that .... still get the error
