Fast way to enter powers of 10
Fast way to enter powers of 10 - It is cumbersome to enter the powers of 10 everywhere. A shortcut would help - 消息
#1 已发布: 2018/5/14 02:34:06
henry crun
henry crun
0个赞,共34个帖子。
It would really help to have a fast way of entering powers of ten.
In electronics, every number has a large exponent and entering 15 * 10 ^ 7 is harder than 15E7
(8 keystrokes vs 4)
I think that there should be an option to treat the special case of E , as the exponent operator.
* is automatically inserted when going from numbers to letters, but this is no problem.
ie new behaviour: 15E6 -> 15*10^6
old: 15E6 -> 15*E6
Problem: variable names like E or E6FilmMass, would need to have an operator explicitly used, and could not use the current automatic * operator insertion
Alternatives: use ctrl+E or alt+E as simple keystroke macro to insert: *10^
#2 已发布: 2018/5/14 08:23:08
983个赞,共6,866个帖子。
Features request ... What features request ?
#3 已发布: 2018/5/17 12:42:41
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
(8 keystrokes vs 4)
Alternative: Define a function E()
2位用户喜欢此帖子
frapuano 2018/5/17 13:27:00, tomracing 2020/9/14 09:05:00
#4 已发布: 2020/8/25 07:01:07
henry crun
henry crun
0个赞,共34个帖子。
not a bad idea. I could also define all the common positives eg
e3:=1000
and maybe the negatives
n3:=10^-3
it would certainly help with matrices as it is more compact too.
With the snippet manager, quite viable.
I do think it would also be good to consider (optionally) using the common exponent notation for display as it is much more compact in arrays. When an array is full of *10^3 it really blows out the size on the page.
#5 已发布: 2020/8/25 07:33:04
1,362个赞,共2,276个帖子。
You can write any multiplier in the unit placeholder of results.
#6 已发布: 2020/8/25 08:05:22
henry crun
henry crun
0个赞,共34个帖子。
True, but only in the very limited number of cases where all elements have the same exponent.
#7 已发布: 2020/8/25 09:40:39
983个赞,共6,866个帖子。
Make your own feature to suit peculiar project.
This notation is native in OriginLab.
Maths e(n).sm (14.94 KiB)已下载 1696 次。
#8 已发布: 2020/8/25 18:17:13
983个赞,共6,866个帖子。
Show the array creation c/w the blown page size.
No monkey see, no monkey do !
#9 已发布: 2020/8/27 11:49:20
1,362个赞,共2,276个帖子。
How about the Table region?
sci.sm (13.5 KiB)已下载 1697 次。
Alvaro 2020/8/28 05:33:00
#10 已发布: 2020/8/28 02:31:05
henry crun
henry crun
0个赞,共34个帖子。
That's a useful solution. I see that when scientific is selected, however, that it loses the units.
Is the table plugin part of the closed source, or an open source add on that might be fixable?
[is it: https://smath.info:8443/!/#public/view/head/plugins/TableRegion ?]
However, I would just prefer to have numeric formatting work well in the first place.
#11 已发布: 2020/8/28 03:51:11
1,362个赞,共2,276个帖子。
The plugin is open source, just like all third-party plugins.
#12 已发布: 2020/8/28 08:18:28
983个赞,共6,866个帖子。
Table region is part of the SS download as old as SS 6179.
Fix what to this superb delivery ?
#13 已发布: 2020/8/29 10:36:56
983个赞,共6,866个帖子。
It does not lose what's not specified.
Table Scientific.sm (20.56 KiB)已下载 1765 次。
