Convert Joule in Nmm - automatic
Convert Joule in Nmm - automatic - 消息
#1 已发布: 2018/6/16 06:56:00
Bastihan
Bastihan
0个赞,共2个帖子。
Hi, Is there anyway that I can set N.mm as default unit instead of J ? I am a structural engineer, working pretty much with Nmm, and I need N.mm everywhere in the calculation smath studio sheet, it is odd to see "J" unit in structural engineering calculation, and I just don't want to change J to N.mm here and there all the times. Thank you very much in advance.
Example
#2 已发布: 2018/6/16 11:27:08
127个赞,共342个帖子。
In the rightmost placeholder after the result type 'N*'mm to change the output unit.
#3 已发布: 2018/6/16 15:59:46
Bastihan
Bastihan
0个赞,共2个帖子。
Thanks! It works great.
Edit: Thank button doesnt work. (Error Occurred)
