1 Pages (8 items)
How to add a region to existing plugin - Messages
Hi All,
I figured I might as well cash-in on the knowledge I got while working on Image Region, and to add a region for my excel_IO plugin.
Now how can I do this? Can a plugin have both smath functions (excel_IO()) and a region support?
Please provide as much guidance as you can - I could use all of it and than some!
Currently all I have is this Class1.vb file.
Class1.zip (8.04 KiB) downloaded 388 time(s).
Thank you!
Thank you!
WroteCan a plugin have both smath functions (excel_IO()) and a region support?
The Maxima plugin is an example. I don't know the implementation details, but the plugin comes with a set of functions like Maxima(), MaximaLog()... and two interactive plot regions, where you can move, zoom and rotate the diagram with the mouse and with a settings menu opening upon double click.
My issue is that i have written XLSXupdate in VB.NET and every other region plugin is in c#.
Can you guys help me with a specific error implementing the region in VB.NET?
I am trying to convert this code from C# to VB.NET
this is my last hurdle. For now.
var buttonImageRegionHolder = new MenuButton("Image", delegate(MenuButtonArgs args)
args.CurrentRegion = new ImageRegion();
Hello Alex,
not sure if this works (is made with a converter)
C# source:
VB.NET translation:
C# source:
MenuButton button= new MenuButton("OxyPlot", this.AddRegion);
private void AddRegion(MenuButtonArgs args)
args.CurrentRegion = new OxyPlotRegion();
VB.NET translation:
Dim button As New MenuButton("OxyPlot", AddressOf Me.AddRegion)
Private Sub AddRegion(ByVal args As MenuButtonArgs)
args.CurrentRegion = New OxyPlotRegion()
End Sub
Alexander O. Melnik 2016/2/23 10:10:00
WroteHello Alex,
C# source:MenuButton button= new MenuButton("OxyPlot", this.AddRegion);private void AddRegion(MenuButtonArgs args) { args.CurrentRegion = new OxyPlotRegion(); }
VB.NET translation:Dim button As New MenuButton("OxyPlot", AddressOf Me.AddRegion)Private Sub AddRegion(ByVal args As MenuButtonArgs) args.CurrentRegion = New OxyPlotRegion() End Sub
Thank you Davide, it worked (unlike the code from many other converters I tried to use). I also learned something in a process which is good :-)
What is the converter you are using? Would be handy for me to get a hold of it...
Good
For simple conversion the online Snippet Converter of SharpDevelop is useful
The code above was produced by Instant VB (Free Edition), it converts the whole project (if the project is not too big); the few times I've used it, it worked fine.
Alexander O. Melnik 2016/2/23 11:53:00
Am I missing something? Do we have one more component for drawing graphs (OxyPlotRegion)?
I don't know, I don't see the plugin within the online list, nor in the Extensions Manager.
1 Pages (8 items)
