How can I evaluate the variables in the loop
How can I evaluate the variables in the loop - 消息
#1 已发布: 2021/9/10 09:24:11
Andrey
Andrey
1个赞,共44个帖子。
Dear Smath-experts,
How can I evaluate the variables in the loop in SMATH?
I want to see how the variables are changing in the loop like in python.
Is what debug is for, but how does it work?
Best regards,
Andrey
#2 已发布: 2021/9/10 09:40:07
1,443个赞,共2,936个帖子。
You can either use the function trace() to show some specific variables (data will be shown in the "output" window on the fly without stopping evaluations) or use the debugger. This is more in "Visual Studio IDE style" and shows you the whole context in a specific point (the breakpoint); this means that the execution is paused when those points are evaluated. To add/remove a breakpoint you can use the context menu (mouse right-click)
#3 已发布: 2021/9/10 13:50:44
983个赞,共6,866个帖子。
You can see it outside the loop, same more vivid.
Cheers ... Jean.
0Anim Landing.sm (56.24 KiB)已下载 1230 次。
#4 已发布: 2021/9/10 17:28:15
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
Dear Smath-experts,
Best regards,
Andrey
Hi Andrey, you can use trace() for check how variables are changing in the loop:
Oscar
#5 已发布: 2021/9/10 21:18:10
983个赞,共6,866个帖子。
... for convenience make it algo style collapsed in utilities.
Thus, you will have it from in-situ command line.
Cheers ... Jean.
Utilities Discrete CUMULATIVE algo.sm (4.16 KiB)已下载 1240 次。
#6 已发布: 2021/9/10 21:34:41
983个赞,共6,866个帖子。
... explore/practice
Utilities Discrete CUMULATIVE algo.sm (5.4 KiB)已下载 1227 次。
#7 已发布: 2021/9/11 09:58:36
983个赞,共6,866个帖子。
Thanks Oscar for trace.
I couldn't make it produce SS 6179.
Was good idea to refactor my old vintage.
Cheers ... Jean.
Utilities Discrete CUMULATIVE algo.sm (14.32 KiB)已下载 1220 次。
#8 已发布: 2021/9/11 10:37:47
600个赞,共1,381个帖子。
trace() or breakpoints are usually de-facto way to go.
Alternatively you can store variables to a matrix.
