Integration Area Under A Line / Curve
Integration Area Under A Line / Curve - Integration Area Under A Line / Curve - 消息
#1 已发布: 2021/1/11 16:34:00
Tow Wai Lim
Tow Wai Lim
0个赞,共42个帖子。
Hi All,
Anyone can help to point me how to integrate equation between a range to find the area unde the curve / function. Been trying loads of way to change the integral equation, but no luck.
Manage to get this done in a simple equation, however can't get when there is a vector
Thanks
#2 已发布: 2021/1/11 17:35:11
983个赞,共6,866个帖子。
Units freak projects top2bottom ▼
Integral (1) DoctoredRed.sm (37.69 KiB)已下载 1159 次。
#3 已发布: 2021/1/11 18:53:56
1,139个赞,共1,805个帖子。
Hi All,
Anyone can help to point me how to integrate equation between a range to find the area unde the curve / function. ...
Hi. For do things between a range you have several options in SMath, like vectorize() or for loops. This is using range variables:
Isn't clear which range do you want in X.point(x)
