Stable: SMath Studio 0.99.7005 (07 March 2019)
Stable: SMath Studio 0.99.7005 (07 March 2019) - 消息
#1 已发布: 2019/3/7 15:32:16
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_7005.Mono.tar.gz (1.36 MiB)已下载 3380 次。
SMathStudioDesktop.0_99_7005.Setup.msi (2.23 MiB)已下载 16610 次。
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
10位用户喜欢此帖子
Василий Николаевич Храмушин 2019/3/30 05:07:00, Martin_B 2019/3/7 16:43:00, bdrunagle 2019/3/7 16:47:00, frapuano 2019/3/7 18:28:00, Davide Carpi 2019/3/7 20:22:00, NDTM Amarasekera 2019/3/7 23:34:00, sergio 2019/3/8 08:01:00, csb531 2019/3/8 11:34:00, Igor Skarine 2019/3/9 19:12:00, Serg 2019/3/7 15:56:00
#2 已发布: 2019/3/7 18:40:44
RegCurry
RegCurry
0个赞,共57个帖子。
I appreciate all your hard work on this software; however, please turn off the popup trying to install the 7005 version every time I open my 6884 version. There are too many plugins that I need that no longer work with the 7005 version.
Thanks again for all your hard work.
Reg curry
#3 已发布: 2019/3/7 20:20:42
1,443个赞,共2,936个帖子。
Go to: Tools > Plugins... > SMath Studio
then enable the option "Don't check for updates"
#4 已发布: 2019/3/8 00:35:13
RegCurry
RegCurry
0个赞,共57个帖子。
I did. However, now I cannot even use the older version with maple or XY plots. This has totally ruined my workflow. Let me know when this is fixed and I will return to Smath.
#5 已发布: 2019/3/8 00:44:30
RegCurry
RegCurry
0个赞,共57个帖子。
Also, there is not Tools>Plugins>SMath Studio
There is only Tools>Plugins>Online gallery
#6 已发布: 2019/3/8 02:27:50
RegCurry
RegCurry
0个赞,共57个帖子。
Thanks for adding in the maple and XY plot plugins.
#7 已发布: 2019/3/8 04:13:27
1,362个赞,共2,276个帖子。
I generally recommend to not upgrade the installed version until you verified that new versions are functional to the level you need.
To test new versions, use the linux version (yes, it runs under Windows and yes it is significantly smaller), unpack it to some directory and add a file named portable.version to that directory. Then you have a sandbox which is totally independent of the "installed" SMath version.
#8 已发布: 2019/3/8 05:41:09
1,443个赞,共2,936个帖子。
Is the first item in the left panel
Once you reinstalled the old program version go in the Extensions Manager (Tools > Plugins) and remove the plugins you have previously updated in the newer version (select each plugin that has a red backkground or didn't work as expected, then click on the trash bin), finally switch the top right button from "Local Storage" to "Online Gallery" and reinstall the extensions you need.
#9 已发布: 2019/3/8 08:59:36
Andrey
Andrey
1个赞,共44个帖子。
Добрый день, уважаемые эксперты SMath.
Спасибо за вашу работу и за новое обновление SMath Studio.
Я обратил внимание на следующую особенность в новоей стабильной версии Smath 0.9.0075.xxx, когда пользователь удаляет строки в документе с помощью клавиши 'Delete‘.
Так не виден маркер удалемых строк и вообще строка статична. Она не двигается вверх, пока жмешь кнопку 'Delete‘. И только потом после операции удаления нескольких строк весь документ сдвигается вверх. А во сколько строк удаляется в процессе удержания кнопки 'Delete‘ - неизвестно . Если риск удалить и сам фрагмент текста или формулы, если маркер находится над ними и пользователь удерживает кнопку 'Delete‘.
С уважением Андрей
p.s. могу выложить видео, но не знаю как на форуме это видео выложить
#10 已发布: 2019/3/14 18:38:52
dio pants
dio pants
16个赞,共180个帖子。
Martin- Thank you for this!
How do you recommend to handle the different plugin versions? If there is a version update to the plugin, is it safe to assume that the updated plugins are 100% backward compatible?
Thanks
Dennis
#11 已发布: 2019/3/15 05:42:22
1,362个赞,共2,276个帖子。
Thanks
Dennis
If you are working with different portable versions, then you have separate directories for each of them. Each version has it's own extensions subdirectory, which you need to fill using the extension manager. Then the extension manager should offer you the plugin versions appropriate for the particular SMath version. Usually this works reliably. Never just copy the extension subdir from some other portable version.
#12 已发布: 2019/3/17 12:14:22
1,362个赞,共2,276个帖子。
German handbook updated.
Available via Extension manager or website.
2位用户喜欢此帖子
Serg 2019/3/17 17:01:00, Martin_B 2019/3/17 14:05:00
#13 已发布: 2019/3/20 10:35:58
1,362个赞,共2,276个帖子。
Andrey, did you deliberately change shortcuts for greek letters?
f Ctrl-G now produces the closed phi sign (\phi in LateX). In previous versions it used to produce the open version of the sign (\varphi)
I'd vote for the old version.
2位用户喜欢此帖子
frapuano 2019/3/20 17:17:00, Andrey Ivashov 2019/3/22 03:55:00
#14 已发布: 2019/3/20 21:56:43
dio pants
dio pants
16个赞,共180个帖子。
they got flipped-flopped- i did not notice until you pointed it out.
i remembered the mention that it was added the 2 'special' greek chars, but I could not figure what it meant until i looked at the symbols panel. if you hover over the symbol, it gives you the shortcut in the new version.
curiously, in 6839, the hotkey work, i do not remember when they got added.
2位用户喜欢此帖子
frapuano 2019/3/21 10:14:00, Andrey Ivashov 2019/3/22 03:55:00
#15 已发布: 2019/3/22 03:54:24
2,344个赞,共4,057个帖子。
Looks like a bug. Will fix it. Thank you!
