@Air
@Air - @Air provides thermodynamic properties and transport properties of moist air. - 消息
#1 已发布: 2013/7/19 06:56:52
1,558个赞,共1,868个帖子。
Functions list: AirPTWV(), AirPVWT(), AirTVWP(), AirPTW(), AirPTF(), AirPWD(), AirPTRW(), AirPTWR(), AirPTWB(), AirPTBW(), AirPBWT(), AirPBRT(), AirPTWU(), AirPTUW(), AirPTWH(), AirPWHT(), AirPHWT(), AirPTWS(), AirPWST(), AirPSWT(), AirVapPT(), AirVapTP(), AirCondPTH(), AirCondPTS(), AirPTWM(), AirPTWK(), AirPTWC(), AirPTHs(), AirPHTs(), AirWX(), AirXW(), AirVer().
Dependences: Mathcad EFI plugin.
Short description:
显示剧透
Links:
1. Mcdair32.dll you can get from here: @Air 4.0 (or from archive below).
You must manually copy the Mcdair32.dll to the userefi folder (".../Application Data/.../91a20d24-c30b-4774-9b1b-4d502a80420f/x.x.x.x/userefi/" ) and TAir32.dll to the \windows\system32\.
air.zip (81.87 KiB)已下载 634 次。
#2 已发布: 2013/7/19 08:24:32
kilele
kilele
134个赞,共397个帖子。
Uni, thank you very much!!
May glory and renown follow you, and gold and w****
Some of these resources could be serve to complement your plugins :
http://en.smath.info/forum/yaf_postsm9354_Built-in-Thermodynamic--and-other--Tables.aspx#post9354
Thanks again and have a nice summer
#3 已发布: 2013/7/19 09:36:32
1,558个赞,共1,868个帖子。
Unfortunately, all of these tools (WinSteam, @Air and @Gas) are free only for 30 days.
#4 已发布: 2013/7/19 09:43:01
325个赞和1个踩,共2,052个帖子。
Does it count using them in SMath as well?
#5 已发布: 2013/7/19 10:16:16
1,558个赞,共1,868个帖子。
I found a link to them on the PTC forum: WinSteam Functions in MathCad. These guys get paid for both these tools: Mathcad and WinSteam. They could pay only for one.
#6 已发布: 2013/7/19 12:56:43
kilele
kilele
134个赞,共397个帖子。
I installed WinSteam and @Air, grabbed McdStm32.dll and Mcdair32.dll, put them into userefi folder and then uninstalled both softwares. SMath does not get to load the plugins reporting the following errors "Tair32.dll not found" ; "TSteam32.dll not found".
#7 已发布: 2013/7/19 13:06:41
1,558个赞,共1,868个帖子。
Copy these two files too (from \WINDOWS\system32\). The fact that Mcdair32.dll and McdStm32.dll are intermediaries of these libraries and do not contain functions themselves. Mathcad libraries contain wrapper functions, they can't work independently.
EDIT: Do not copy. They must be in \system32\ directory. When you uninstalled the program, these files have disappeared. SMath Studio tries to load Mcdair32.dll and it tries to load TAir32.dll. Usually it is sufficient to put the library in the same place where the mathcad library is located. But not in this case.
