2D Plot Vectorised vector
2D Plot Vectorised vector - Not sure this is possible - 消息
#21 已发布: 2021/1/21 13:02:40
983个赞,共6,866个帖子。
Not sure why you cannot open.
It is a persisting random bug, from unknown.
Windows not recognizing *.sm format, at random and why.
That bug has not been isolated ... Russian Roulette ?
#22 已发布: 2021/1/22 04:09:05
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
A good way is to work units-less, then append silent units.
Calculation without units. Units are presented at the end of the calculation
Heate.sm (9.03 KiB)已下载 1305 次。
#23 已发布: 2021/1/22 11:28:29
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Ber7,
Still off by a factor of units (12 to convert inches to ft). I split this to a NEW TOPIC. I've never used the Mat2System function.
#24 已发布: 2021/1/22 11:46:23
983个赞,共6,866个帖子。
Thanks Ber7, nice sterilized units
Heate 6179.sm (14.51 KiB)已下载 1256 次。
#25 已发布: 2021/1/22 11:49:28
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
But it's wrong
#26 已发布: 2021/1/22 12:05:10
983个赞,共6,866个帖子。
But it's wrong
Just divide something by 12
#27 已发布: 2021/1/22 12:08:24
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
That's the problem. Units are important and impact the way the function is not working. Divide t by 12 and the The x column no longer starts with 4, but 1/3 and the y column is correct. Leave it as is and the x column is correct and the y column is wrong.
#28 已发布: 2021/1/22 13:09:45
983个赞,共6,866个帖子。
I love Ber7 method, saved it personal.
Easy to scale/reconciliate from your original by 'λ'
Unit Waterloo Otherwise.sm (15.32 KiB)已下载 1214 次。
#29 已发布: 2021/1/22 13:27:55
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
In dimension Ro there is a ft. Therefore, the size t
should be expressed in ft. The bug has been fixed.
Heate in-ft.sm (9.77 KiB)已下载 1265 次。
#30 已发布: 2021/1/22 14:34:41
983个赞,共6,866个帖子。
Therefore, the size tshould be expressed in ft.
Wait and watch what Elsid will comment !
Units system is really a Monkey Business, isn't ?
#31 已发布: 2021/1/22 14:49:53
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Correct, divide by 12 ... in this case.
This elegant function appears to work on all empirical equations, as long as the user input units are double checks for consistent cancellation.
Is the descriptor of the function accurate? Heat Capacity Function_Sys2Mat Ber7.sm (15.07 KiB)已下载 1756 次。
#32 已发布: 2021/1/23 14:51:29
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Change your file a bit and added clarifications
Heat t Ber7.sm (16.94 KiB)已下载 1272 次。
ElSid 2021/1/23 19:07:00
