FUNCTION MATRIX ADR SHEET
FUNCTION MATRIX ADR SHEET - Need help manipulating the matrix - 消息
#1 已发布: 2021/1/9 19:19:46
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix.ADR.sm (127.5 KiB)已下载 1211 次。
Thank you
#2 已发布: 2021/1/9 22:34:24
983个赞,共6,866个帖子。
Quick brute force for a range of values, AFAIU.
Cheers old Collab Elsid ... Jean
ADR brute force.sm (150.39 KiB)已下载 1228 次。
#3 已发布: 2021/1/10 01:02:58
983个赞,共6,866个帖子。
... here is a more complete search.
ADR brute force augmented.sm (159.59 KiB)已下载 1200 次。
#4 已发布: 2021/1/10 21:17:49
983个赞,共6,866个帖子。
Don't miss the Truth Table Companion in Samples.
#5 已发布: 2021/1/10 23:16:00
600个赞,共1,381个帖子。
Aaah now I get what you meant.
This should solve your problem.
Deleted previous post.
#6 已发布: 2021/1/11 12:56:03
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
#7 已发布: 2021/1/11 13:25:58
600个赞,共1,381个帖子。
InterpBilinear() is in the 'Custom Functions' plugin.
Basically an interpolation with two variable.
Good and useful function.
#8 已发布: 2021/1/11 14:09:54
983个赞,共6,866个帖子。
... from the attached example,
get inspired to construct the data ready for matrix interpolation.
Elsid Spline Table.sm (19.1 KiB)已下载 1215 次。
