Mathcad While / Smath For
Mathcad While / Smath For - Help with the structure - 消息
#1 已发布: 2021/9/7 17:07:55
metrvg
metrvg
0个赞,共5个帖子。
Hello guys, please your help! I've trying for weeks to do the equivalent WHILE in Smath Studio... a big tool for me. But I really cant figure it out, after watching thousands of videos and web pages. This might be a dumb question, but I'm kinda desperate.
I keep getting Z is not defined.
See the following captures:
Mathcad
Smath Studio
Thank you very much in advance.
#2 已发布: 2021/9/7 17:36:04
600个赞,共1,381个帖子。
SMath vectors/matrices don't start with 0 index.
First matrix/vector element gets the index 1.
Redesigning your code should make it tick.
Either make your indexes +1 or change your range to start with 1.
metrvg 2021/9/14 17:06:00
#3 已发布: 2021/9/8 11:33:22
983个赞,共6,866个帖子。
The mountains of Mathcad that I converted for Smath were done simply.
1. From the Mathcad default index 0, save the result.
2. set Mathcad ORIGIN 1
3. Run the program, doctor as indicated by the red message.
I still have a gorgeous Mathcad ORIGIN 0 that couldn't be
converted/doctored ORIGIN 1 ... Damned mystic to me !
Cheers ... Jean.
#4 已发布: 2021/9/8 16:35:53
983个赞,共6,866个帖子。
Does it make sense to sanity Smath vs Mathcad more generally ?
Page9 Sanity Mathcad.sm (8.19 KiB)已下载 1452 次。
#5 已发布: 2021/9/10 02:12:09
wty3000
wty3000
0个赞,共5个帖子。
when I download the attachment, run it,
the error happens : "j is not defined"
Is it my PC's problem?
#6 已发布: 2021/9/10 19:12:50
983个赞,共6,866个帖子。
PC problem ? Maybe as no visitor reported problem.
#7 已发布: 2021/9/11 10:44:48
600个赞,共1,381个帖子。
Could you please uninstall SMath and delete your smath config directory.
Directory should be in "C:\Users\\AppData\Roaming\SMath\".
Delete the SMath directory in Roaming completely, purge it.
And could you please download new version again and install it?
#8 已发布: 2021/9/12 11:35:40
983个赞,共6,866个帖子。
You can probably doctor wrt your SS version.
Cheers ... Jean.
#9 已发布: 2021/9/14 17:05:39
metrvg
metrvg
0个赞,共5个帖子。
Guys, thanks for your advices, i've been progressing with Smath... BUT, I reached a new issue... and I still don't get it...
i even did the calls step by step marked in red.
What can be wrong in the sintax??
Check this out:
Mathcad
Smath
Thank you very much in advance!
#10 已发布: 2021/9/14 17:25:05
600个赞,共1,381个帖子。
What can be wrong in the syntax??
We can't really tell what is the matter without the file.
I guess you tried to see the result in same region with the algorithm.
Same region result evaluation won't work with multi-line calculations.
But it will give you the correct results in a separate evaluation.
The syntax seems to appear correct. There is no problem with syntax.
When I wrote everything as you did, it just works.
Here is your algorithm written from scratch.
syntax.sm (5.16 KiB)已下载 1293 次。
metrvg 2021/9/14 19:37:00
