1页(4条)
Displaying problem (98.6484 portable) on Win10 - Display does not "refresh", shows artifacts - 消息
from today on I got some problems with the display of Smath.
Working on the SMath 98.6484 (unoffial, portable with maxima plugin).
I had a similar problem right from the start whe i used this version (in february). The problem could be solved by deactivation a plugin (image region).
But from today on, I got the problem again, even so I didnt acitvate this plugin.
I guess something changed with the last update of win 10 (they didnt ask ;-) -> windows-style ;-)).
I will attache some screenshots.
Thanks!
未找到文件。未找到文件。
Robert
Thanks!
未找到文件。未找到文件。
Robert
Can you remove completely the plugin?
Image region DPI issue was fixed 7 months ago.. It works well on my WIN10 machine. Try updating to latest?
https://en.smath.info/forum/yaf_postsm44313_Editable-Image-Region---Plugin-Update.aspx#post44313
First of all, thanks for your reply.
Well, I already installed the newest version, which is supposed to contain the newest plug in version (as on the link you sent me)
(https://en.smath.info/forum/yaf_postsm44313_Editable-Image-Region---Plugin-Update.aspx#post44313), but still the same problem.
BUT, deleting the plugin does work ;-)!!
Thank you.
Robert
Thank you.
Robert
1页(4条)
