Time for calculating the variance() & stddev() from csv file
Time for calculating the variance() & stddev() from csv file - 消息
#1 已发布: 2024/4/3 20:10:07
MN283
MN283
0个赞,共2个帖子。
Hi SMath community,
I would like to calculate the variance() and StdDev() of the second column "V(3v3)" of the attached file with 50k datapoints. Unfortunately the calculation takes forever (aborted it after 30min).
The file is an export of a circuit simulation result (gaussian tolerance distribution in LTSpice). Originally it is in .txt-Format and it seems that I have to convert it in excel to .csv-Format before I can use is. I attached both, the original LTSpice export (.txt) and the converted one from Excel (.csv).
How can I handle this in sMath?
Archiv.zip (585.47 KiB)已下载 534 次。
Thanks in advance,
Marc
#2 已发布: 2024/4/3 22:34:03
1,443个赞,共2,936个帖子。
With import file functions you might need to set the optimization to numeric to speed up the loading.
#3 已发布: 2024/4/3 23:32:05
MN283
MN283
0个赞,共2个帖子。
Optimizations were all set to numeric - did not help. What helped was that I substituted the statistic function variance() and StdDev with the original/native formula for the variance and standard deviation.
This speeds it up to around 1s.
Don´t know what happens inside the functions of the statistic plugin but it is very slow.
Thanks
#4 已发布: 2024/4/11 06:24:17
Fikret Atalay
Fikret Atalay
2个赞,共24个帖子。
I have noticed the same thing; the built-in function for standard deviation takes forever but the calculation runs pretty quickly if I just code in the formula in the worksheet.
#5 已发布: 2024/4/12 16:53:41
1,443个赞,共2,936个帖子。
Confirmed, the bottleneck seems to be in the final ouput processing to return the result from the equation [f.e. 1/{n-1}*sum(((el(X,i)-mean)^2),i,1,n)) for StdDev]; no idea not sure what could be the cause...
