SMath File Crashes Automatically
SMath File Crashes Automatically - Messages
#1 Posted: 2021/11/16 20:11:12
metu_engineer_1
metu_engineer_1
0 likes in 2 posts.
2 hours ago I have finished my task then I saved it and closed it. However, to take necessary information from my worksheet, I can not open my file. When I try, it automatically terminate itself.Can you help me about my issue?
q2.sm (27.92 KiB) downloaded 1243 time(s).
Thanks.
#2 Posted: 2021/11/16 20:21:35
597 likes in 1,377 posts.
You can check smath files with a text editor.
An empty region between lines 520-530 was causing force crash.
Could you please check and inform if this works?
q2.sm (27.46 KiB) downloaded 1299 time(s).
#3 Posted: 2021/11/16 20:28:33
metu_engineer_1
metu_engineer_1
0 likes in 2 posts.
Thank you so much for your effort, you saved my whole day...
These are lines between 520-530.Which line creates the bug? In case, I will encounter this situation again in future, maybe I will be able to fix it myself.
"I appreciate the way you help people!"
Best Regards..
#4 Posted: 2021/11/16 21:27:15
Your work sheet works OK SS 6179
q2.sm (24.72 KiB) downloaded 1275 time(s).
#5 Posted: 2021/11/16 21:39:03
Best Regards..
Culprit is occasionaly lines contain >\[REGION[xxxxxxxx]]\.
They usually have some context you did enter.
Some title, some text, an image, etc.
But as you can see in this, it is empty.
I look for them at first, then others.
Don't delete every REGION containing regions.
Don't forget to backup your file too.
Even it is not opening.
