Beta: SMath Studio 0.99.7769 (09 April 2021) - 消息
WroteAny suggestions on how the text is displaying in controls?
CheckBoxList Region fixed now. Please update it using Extensions Manager.
2位用户喜欢此帖子
WroteCheckBoxList Region fixed now. Please update it using Extensions Manager.
You rock, Andrey! Thank you - not just for this quick fix, but also for your dedication to this whole project.
Jason McCool
Robbins Engineering
Little Rock, AR, USA
WroteActually one thing we really want is bold and italic font functions to work with linux.
Sign-in option has secondary priority compared to this at the moment if you ask me.
Yesterday I've spent some time on the issue regarding font style (bold/italic) in Linux and the only information I've found is this bug in Mono: https://github.com/mono/mono/issues/17314
Tried to use suggested workaround, but it seems it is not applicable for us because of too slow performance.
Here is a version of SMath Studio with my attempt to use workaround: http://smath.com/file/2wQhP
It works, but it is extremely slow - almost impossible to work with real worksheets.
Will see, maybe another solution will be found in future.
I will definitely try your solution.
If it won't be applicable, so be it.
After all this is drawback of mono.
We accepted our fate. (swh)
Edit: Your solution works with fonts.
But it has very slow performance indeed.
Not "not usable" level but I won't prefer to use this daily.
I will keep this version just for print purpose.
Thanks Andrey.
Thanks Andrey.
Andrey Ivashov 2021/4/14 02:52:00
WroteWe accepted our fate. (swh)
I did it!
Please download https://en.smath.com/file/UhVpV and replace SMath.Drawing.dll from the distribution package with downloaded one.
Everything should work fast enough! Will include this workaround into the next build.
2位用户喜欢此帖子
WroteWroteWe accepted our fate. (swh)
I did it!
Yes, it performs very fast just as "usual" builds.
I have checked it only 2-3 minutes yet so far so good.
Everything seems in order, well done.
