Problem with Optimization
Problem with Optimization - Messages
#1 Posted: 2012/1/16 07:28:25
Edward Ulle
Edward Ulle
21 likes in 182 posts.
The following file will crash if Optimization is set to Symbolic with SMath 0.9. Just something for Andrey to play with in his spare time. :d
https://smath.com/wiki/GetFile.aspx?File=forum_attach%2fTheWizEd%2f4100422_New_Crane_Beam.zip
Ed
#2 Posted: 2012/1/17 04:27:51
2,326 likes in 4,013 posts.
Thank you! Will fix it soon.
Regards.
#3 Posted: 2012/1/17 04:52:40
Edward Ulle
Edward Ulle
Andrey,
Could you explain the purpose of the Symbolic and Numeric Optimization and when either is appropriate. If I turn on Numeric Optimization and hoover over an equation I see fractions with numbers with 10^15 or higher. I believe its to come up with a denominator which is the largest integer value. Why not just use the floating point value of the equation?
Ed
#4 Posted: 2012/1/23 19:00:09
Fixed.
Regards.
Radovan Omorjan 2012/1/23 20:36:00
