Transform formulas
Transform formulas - 消息
#1 已发布: 2023/2/5 17:43:18
Marco
Marco
0个赞,共10个帖子。
Hello
I would like to convert formulas, as an example v=s/t what is s=?
and then only as formula s=v*t
#2 已发布: 2023/2/5 18:12:05
600个赞,共1,381个帖子。
SMath symbolic solver capability is limited.
These type of formulas can't be solved by numeric solvers.
You will need a plugin, either maple or maxima.
They can be installed via Tools>Plugins.
Maple is compact, easy to use, one click install.
Maxima is more capable but third party installation required.
Just use boolean equal sign for your formula.
Don't forget to change optimization to Symbolic via Right Click menu.
#3 已发布: 2023/2/5 18:16:25
Marco
Marco
0个赞,共10个帖子。
alright thanks I will try first maple then maxima.
the formula was only as example I would change the formula for the safety factor for bending on a shaft.
#4 已发布: 2023/2/5 18:17:25
600个赞,共1,381个帖子。
You are a new user, so remind this. Jean has his own agenda.
His intention will not be helping you, just read his replies and go on.
If you can't get what he is saying he is probably giving you wrong answer.
All new users are confused by his meaningless posts.
#5 已发布: 2023/2/5 18:21:29
Marco
Marco
0个赞,共10个帖子。
hahahaha nice so he is the Smath studio forum Troll/golum
but thanks for getting me to this point.
#6 已发布: 2023/2/5 20:53:05
Marco
Marco
0个赞,共10个帖子。
i try it and looks like its work thanks.
for obvious reasons i do not know yet if it is so correctly converted I will try it tomorrow with a whole calculation and then see if it is right.Have a nice evening
formel umstellen
( google search keywords ((hopefully it works out)) smath formulas transform formeln umstellen )
#7 已发布: 2023/2/6 13:23:00
600个赞,共1,381个帖子。
It should work fine.
If you can't get what you seek, you can post your file for further assistance.
Ask anytime for aid, there will be an experienced user willing to support.
SMath community is kind and helpful. Well, apart from Jean.
NDTM Amarasekera 2023/2/6 13:33:00
