A worksheet path must be set as input
A worksheet path must be set as input - Error with Run() - Messages
#1 Posted: 2021/4/21 20:34:01
Billy Chan
Billy Chan
0 likes in 4 posts.
I get the error: "A worksheet path must be set as input" when running the Run() command. It runs fine with the example file "Run Example".
Any help please?
#2 Posted: 2021/4/22 08:35:11
1,441 likes in 2,932 posts.
Assuming calcFile file path exists, should be because encoded strings. I?ll fix it ASAP.
#3 Posted: 2021/4/22 08:59:13
Billy Chan
Billy Chan
0 likes in 4 posts.
Thanks Davide.
"CalcFile" is defined by a string of the filename with .sm. The file is in the same folder as the master worksheet.
#4 Posted: 2021/4/25 19:50:45
Fixed and released for the latest beta.
#5 Posted: 2021/4/26 06:28:21
Billy Chan
Billy Chan
0 likes in 4 posts.
I've tried the Run() plug-in using SMath 0.99.7786.571 and it seems to be working.
Thanks very much for the prompt fix!
