calculation in table
calculation in table - 消息
#1 已发布: 2017/11/14 12:39:44
Paulius
Paulius
0个赞,共11个帖子。
Is possible to make calculation in table, like excel?
#2 已发布: 2017/11/14 16:34:30
Alexander O. Melnik
Alexander O. Melnik
127个赞,共498个帖子。
Not that I am aware off, but you can "connect" to EXCEL if you have it on your windows machine:
https://en.smath.info/forum/yaf_postst4375_Plugin---EXCEL--2003--I-O-with-recalculation-and-export-to-PNG.aspx
#3 已发布: 2017/11/14 20:09:50
983个赞,共6,866个帖子。
Your question is too vague, a bit of work sheet would help.
In short: there is no known limit about what Smath can do
within a matrix [its own matrix] wrt the project you are Engineering.
Then, you may send to Excel via Alex plugin.
Alex, please correct me if wrong !
Cheers.
#4 已发布: 2017/11/15 04:54:27
Peter J Francis
Peter J Francis
0个赞,共18个帖子。
Hi Paulius,
I had a similar problem.
I wanted to create a table of values for a project at work that could be easily read by non SMath people (i.e. I wanted a nice looking table but also array names with text to identify the value rather than numbers)
Some of the values were fixed (sizes , powers or text ) but I needed to perform calculations on some of the values and incorporate it in a table.
I came up with the following method using TableRegions , although it looks a little complicated it works great and generates a great looking table and I can use arrays with meaning full text identifiers.
The attached file is annotated so should be fairly self explainatory and there are some examples of how to use the values at the bottom.
If you have a problems with it let me know.
TableRegion example by PJF.sm (30.69 KiB)已下载 1535 次。
Peter
Peter J Francis Twitter: @PeterJFrancis Thermal Engineer , Maker , Pilot
#5 已发布: 2017/11/15 09:26:33
Paulius
Paulius
0个赞,共11个帖子。
Tnank You Peter
#6 已发布: 2017/11/15 11:49:34
983个赞,共6,866个帖子。
Thanks Peter: gorgeous ! mm² ... mm[Alt+253]
Hi Paulis ... here is some bed time reading
Rotate Eol.sm (28.47 KiB)已下载 1397 次。
Utilities Matrix Truth Table.sm (59.2 KiB)已下载 1326 次。
0Anim Brownian.sm (9.94 KiB)已下载 1298 次。
2D Fill Stem.sm (12.71 KiB)已下载 1306 次。
0Anim Ellipse.sm (13.85 KiB)已下载 1310 次。
0Anim Analemma.sm (29.24 KiB)已下载 1327 次。
Inst_Colebrook Pipe Data.sm (60.09 KiB)已下载 1341 次。
2D Isometric Copy.sm (77.29 KiB)已下载 1249 次。
Utilities Matrix Treasury Copy.sm (355.68 KiB)已下载 1284 次。
Rotate Image RGB.sm (348.52 KiB)已下载 1341 次。
Rotate Breather [4 Orientations].sm (1000.05 KiB)已下载 1134 次。
Image ZOOM Cosmos RGB.sm (1.79 MiB)已下载 1317 次。
2位用户喜欢此帖子
Peter J Francis 2017/11/15 13:02:00, frapuano 2017/11/15 16:58:00
#7 已发布: 2017/11/16 02:06:31
Alexander O. Melnik
Alexander O. Melnik
127个赞,共498个帖子。
Cheers.
Agree with Jean - you can do all sorts of operations in SMath with matricies and then present them as a table region OR you could use excel to do an present all the table stuff for you.
