Beta: SMath Studio 0.99.6955 (16 January 2019)
Beta: SMath Studio 0.99.6955 (16 January 2019) - 消息
#1 已发布: 2019/1/15 19:27:36
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_6955.Mono.tar.gz (1.35 MiB)已下载 2438 次。
SMathStudioDesktop.0_99_6955.Setup.msi (2.23 MiB)已下载 4927 次。
Please note:
  1. There are some known bugs with Worksheet scrolling - will be addressed soon;
  2. There are some UI issues on environment with high DPI (some Custom plug-ins may not be scaled correctly).
    Please use the following to disable high dpi support if required:
3位用户喜欢此帖子
frapuano 2019/1/16 04:11:00, sergio 2019/1/16 06:15:00, Davide Carpi 2019/1/16 08:13:00
#2 已发布: 2019/1/15 22:13:40
983个赞,共6,866个帖子。
What about the indefinite integral ?
5346 had the the indefinite integral in the f(x)menu, thus available for maple.
It was removed 6179, but it could be called within maple maple(int,)
This last facility does not work anymore.
About that, Davide replied 19 days ago:
"I cannot reproduce the autocomplete of int in any SS version, neither changing the date on the machine, and I'm not aware that there ever were such behavior...
however, I don't think it is a desirable feature; how would you access or create any int~ variable/function if the program triggers the autocomplete while you are typing? (and imagine this extended to any function...)"
#3 已发布: 2019/1/16 03:59:32
2,344个赞,共4,057个帖子。
To all developers:
As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement:
- Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.
or
- All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.
All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect.
All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono).
Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself.
Best regards, Andrey Ivashov.
#4 已发布: 2019/1/16 17:01:53
983个赞,共6,866个帖子。
Another question ... what do you calculate ?
Gamma [15 D Alvaro].sm (9.33 KiB)已下载 1429 次。
#5 已发布: 2019/1/17 17:16:41
983个赞,共6,866个帖子。
As it looks, not that many Smath latest version users are interested.
#6 已发布: 2019/1/17 18:59:53
2,344个赞,共4,057个帖子。
Thank you Jean. I will check.
#7 已发布: 2019/1/17 19:01:00
2,344个赞,共4,057个帖子。
Davide answered you correctly in a separate topic.
#8 已发布: 2019/1/17 21:37:31
983个赞,共6,866个帖子。
Thanks in advance Andrey for eventually doctoring.
I have tested exhaustively Alvaro Γ(x) 15 decimals vs Mathcad
Further, Definite Integration does not need be vectorized.
Gamma [15 D Alvaro].sm (10.94 KiB)已下载 1455 次。
