Max pos number error
Max pos number error - An equation result gives an error when assigned to a variable, but no error w/o assignment. - 消息
#1 已发布: 2012/9/24 17:00:28
dking
dking
0个赞,共2个帖子。
The current problem is that the output of my function can only be shown but not assigned to a variable. When I try to view the value stored in the variable I'm given a max positive number error.
The initial problem began with the equation working only outside of a function, but when written as a function it would give a max positive number error.
Through trial and error I found that I could break up the equation into two steps, and now the function works aside from the assignment error stated above.
Max Number Error.sm (4.31 KiB)已下载 1430 次。
#2 已发布: 2012/9/24 18:15:39
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Try to apply the function eval:
F4=eval(F4(N))
Regards, Ber7
#3 已发布: 2012/9/25 13:11:36
dking
dking
0个赞,共2个帖子。
Thanks, that works.
