Maxima Plot path error
Maxima Plot path error - 消息
#1 已发布: 2019/3/21 14:41:14
Topsi
Topsi
0个赞,共8个帖子。
Hello SMath user,
Plotting with Maxia doesn't work. Insert /Maxima/ 2D-3D plot
results in an error message..: Cannot find the path (see appendix).
In the German language the character o with arc does not exist.
Here the path name contains the a with points ä . Can I use the
Set path Are there other possibilities? Want to use Maxima plot
not with 3DPlot.
Thank you
topsi
#2 已发布: 2019/3/21 18:08:11
1,362个赞,共2,276个帖子。
Normally the plugin should be unicode-proof. It uses SBCL. Does the plot work in wxmaxima?
