LM Algorithm !!
LM Algorithm !! - 消息
#1 已发布: 2019/7/3 05:03:43
shinavn
shinavn
0个赞,共2个帖子。
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Shina
#2 已发布: 2019/7/3 09:51:17
325个赞和1个踩,共2,052个帖子。
Shina
Could you be more specific please. What example are you talking about?
Davide Carpi 2019/7/3 10:32:00
#3 已发布: 2019/7/3 11:51:07
983个赞,共6,866个帖子。
Please, share your application.
LM covers a good % of all fits in Mathcad.
Cases LM fails, Conjugate Gradient is the sole rescue.
Many model functions can only be fitted by hand.
#4 已发布: 2019/7/10 10:05:59
983个赞,共6,866个帖子。
Shina
You are right About LM, however not so simple.
al_nleqsolve, LM, ConjugateGradient that produce in Smath, all dependent
upon initials and reflexivity of the model +++ the approach technique.
Data reduction is a great approach technique [Kirby, Thermocouples ...]
In Mathcad LM as well as CG, a technique that works well to initialize
wrt many models is to pass manually initials through 2 points.
That was not explored with Carlos LM.
That technique through 2 points did work well in some Smath fit,
but failed in other fits. Maybe you are working hard on that stuff ?
Attached for the interest of this visit.
Genfit Chemist.sm (34.16 KiB)已下载 1319 次。
Genfit Minimize Rational KHL.sm (45.36 KiB)已下载 1319 次。
Genfit Pharmacokinetics.sm (41.84 KiB)已下载 1342 次。
#5 已发布: 2019/7/11 10:38:07
983个赞,共6,866个帖子。
... for your delight => try Laser
Genfit Convolution Laser.sm (231.03 KiB)已下载 1385 次。
