Bug in funtion f(x) release 97.5189
Bug in funtion f(x) release 97.5189 - f(x) generates Summation instead of function - 消息
#1 已发布: 2014/5/5 08:44:56
Renaud Pelletier
Renaud Pelletier
0个赞,共2个帖子。
x=1..10
x=1
2
result
f(x)=385
which is the summation
it should show the array with values for each values of x
Bug Function .sm (3.08 KiB)已下载 1398 次。
#2 已发布: 2014/5/5 11:08:12
325个赞和1个踩,共2,052个帖子。
It is not a bug, it is the SMath feature. You've got the scalar product of two vectors.
[MATH=eng]x*x=385[/MATH]
If you want the elemental operation - you should use loops
[MATH=eng]for(i,range(1,length(x)),el(y,i):el(x,i)^2)[/MATH]
[MATH=eng]y=mat(1,4,9,16,25,36,49,64,81,100,10,1)[/MATH]
or Maxima plugin
[MATH=eng]Maxima(f(x))=mat(1,4,9,16,25,36,49,64,81,100,10,1)[/MATH]
#3 已发布: 2014/5/7 02:21:41
Renaud Pelletier
Renaud Pelletier
0个赞,共2个帖子。
Thanks
