List calculation
List calculation - 消息
#1 已发布: 2017/11/16 13:14:55
pierre
pierre
2个赞,共17个帖子。
Could you tell me if their is any way to loop through a list the Way mathcad does with the I:=0..n, as a "global" methode (not inside a formula).
Below a screenshot of the case
Image explicative
Thank you for your help
#2 已发布: 2017/11/16 14:03:03
983个赞,共6,866个帖子。
No limit, even from more savant list.
ODE rkf Integrate [rkf4 2 parameters Algo].sm (120.69 KiB)已下载 1081 次。
#3 已发布: 2017/11/16 14:15:17
983个赞,共6,866个帖子。
#4 已发布: 2017/11/16 14:18:27
983个赞,共6,866个帖子。
#5 已发布: 2017/11/16 14:42:21
pierre
pierre
2个赞,共17个帖子。
Thanks for your reply.
I think i need to be more specific with my question.
I will make an exemple extracted from the internet (page 16)
link to the PDF
As you can see the loop is done for the whole spreadsheet, and it makes calculation notes a lot clearer.
#6 已发布: 2017/11/16 15:01:37
1,443个赞,共2,936个帖子。
Here you have:
The arrow over the math is the function vectorize(), and that's what you need to apply the elements of the ranges avoiding loops (that is the other way to accomplish the task)
Arie 2017/11/16 17:11:00
#7 已发布: 2017/11/16 15:14:25
pierre
pierre
2个赞,共17个帖子。
Thanks a lot for the explanation!
You made my day!
#8 已发布: 2017/11/16 18:52:33
983个赞,共6,866个帖子。
You made my day!
Visit "Calculation in Table"
Read more in the 12 Smath work sheets attached.
