Unofficial portable distribution with Maxima
Unofficial portable distribution with Maxima - 消息
#1 已发布: 2016/2/11 03:20:26
genf
genf
6个赞,共72个帖子。
Thank you for your assembly!
I use them for a long time! Everything works well! Long time no update from you. Worth the wait?
#2 已发布: 2016/2/11 10:26:17
1,362个赞,共2,276个帖子。
I hope to update the distribution by end of march (2016)
7位用户喜欢此帖子
Serg 2016/2/11 10:36:00, Davide Carpi 2016/2/11 11:07:00, ioan92 2016/2/11 11:11:00, sergio 2016/2/11 11:16:00, Alexander O. Melnik 2016/2/11 12:34:00, Radovan Omorjan 2016/2/11 13:02:00, Oscar Campo 2016/2/12 12:10:00
#3 已发布: 2016/5/5 16:45:26
urs elrod
urs elrod
0个赞,共1个帖子。
thank you for your wonderful package. Will you also include a newer version of maxima then maxima 5.34? My firewall creates a lot of problems with maxima 5.34. I experienced no severe interferences with maxima 5.38 and the firewall but the communication between Maxima and SMath was in my case insufficient.
Urs Elrod
#4 已发布: 2016/7/20 02:20:16
genf
genf
6个赞,共72个帖子。
Good afternoon!
We are looking forward to update a portable assembly.
#5 已发布: 2016/8/12 05:43:15
genf
genf
6个赞,共72个帖子。
Good afternoon!
If you are unable to upgrade, then tell me how you created it. It is possible to do, if we can understand.
Thank you.
Make it done as you describe, but that some plugins are buggy (Maple, Maxima). So the work, but not in the last portable version of Martin.
#6 已发布: 2016/8/12 07:00:41
1,443个赞,共2,936个帖子。
Creating an updated portable distribution is quite simple:
  1. Create a portable version of SMath Studio (instructions in the spoiler);
    显示剧透
  2. Copy the "Maxima-5.34.1" folder from the one in the existing portable distribution to the same position in the new one;
  3. Download Maxima plug-in and all the plug-ins you need;
  4. in the folder "{PORTABLE_PATH}\extensions\plugin\44011c1e-5d0d-4533-8e68-e32b5badce41" paste the file "maxima.xml" copied from the same location of the existing portable distribution
The problem with shared Maxima's symbolic functions (those handled by MaximaTakeover - diff, int, etc...): seems that in the latest SMath Studio distributions if a function is overridden in the name but is not overridden as function is no more possible to call the function from another plugin (as stated by Martin, you can use MaximaTakeover("all") to use the Maxima engine to do the work)
2位用户喜欢此帖子
ElSid 2016/8/15 15:53:00, Serg 2016/8/19 04:58:00
