Stable: SMath Studio 0.99.6884 (06 November 2018)
Stable: SMath Studio 0.99.6884 (06 November 2018) - 消息
#1 已发布: 2018/11/6 15:39:16
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_6884.Mono.tar.gz (1.35 MiB)已下载 6081 次。
SMathStudioDesktop.0_99_6884.Setup.msi (2.23 MiB)已下载 44678 次。
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
12位用户喜欢此帖子
Arie 2018/11/6 15:52:00, Fridel Selitsky 2018/11/6 16:30:00, Davide Carpi 2018/11/6 17:08:00, sergio 2018/11/6 17:57:00, bdrunagle 2018/11/6 18:39:00, NDTM Amarasekera 2018/11/6 22:37:00, Вячеслав Мезенцев 2018/11/7 03:13:00, Igor Skarine 2018/11/7 12:51:00, IVR 2018/11/9 12:53:00, Serg 2018/11/13 04:30:00, Василий Николаевич Храмушин 2018/11/17 15:46:00, Mikka 2018/11/20 07:42:00
#2 已发布: 2018/11/6 17:07:50
1,443个赞,共2,936个帖子。
4位用户喜欢此帖子
IVR 2018/11/9 12:54:00, Andrey Ivashov 2018/11/6 18:27:00, Вячеслав Мезенцев 2018/11/7 02:42:00, NDTM Amarasekera 2018/11/7 05:50:00
#3 已发布: 2018/11/9 17:44:02
dio pants
dio pants
16个赞,共180个帖子。
Are there any plugin incompatibilities known which work and which dont work?
#4 已发布: 2018/11/10 14:24:21
Brian Runagle
Brian Runagle
13个赞,共27个帖子。
In response to Davide's documentation post, the first time I tried to open the file on my Windows 7 PC the topics on the left-hand pane displayed correctly but the right-hand pane was blank.
In case anyone else has the same problem, I found that it displays correctly when saved in the Users area - C:\Users\'username'\ - and opened from there.
I think this must be a Windows 'Security' feature.
Brian
#5 已发布: 2018/11/10 15:00:01
1,443个赞,共2,936个帖子。
Brian
Yes, it is a security feature of Windows.
here in the accepted answer you can see different approaches to solve it.
bdrunagle 2018/11/10 16:21:00
#6 已发布: 2018/11/18 06:23:42
600个赞,共1,381个帖子。
I can't copy or cut and paste any region (text, writer, image, etc) from header/footer.
It is just can't be pasted to anywhere in Smath.
Have a nice sunday folks,
#7 已发布: 2018/11/18 09:03:08
983个赞,共6,866个帖子。
Can't understand what you mean by text, writer, image from header/footer
#8 已发布: 2018/11/18 09:45:58
600个赞,共1,381个帖子。
because you are on way outdated version (6179) of smath. I am talking about 6884. there is a new functionality which is introduced in 6873, header/footer areas.
#9 已发布: 2018/11/18 12:41:37
983个赞,共6,866个帖子。
... what is it supposed to do, or what did you expect it would do ?
You let suppose it would take an image in either or both header/footer ?
#10 已发布: 2018/11/18 17:04:04
600个赞,共1,381个帖子。
I will try to explain, from the beginning.
There are header and footer areas for MS Office Word, Libreoffice Writer, LaTeX, etc for decades.
You know, some reports or calculations are not just one or two page.
Header and footer areas helps people to maintain some crucial information for the multiple paged reports they assembled.
Project name, company logo, page number, etc. Please don't mention the one-lined "&[DATE]&[TIME] &[PAGENUM]/&[TOTAL]" thing. It is not the same thing.
So our beloved Smath has this helpful functionality, thanks to Andrey.
So the problem is, you can directly write into header or footer in Smath. You can even paste company logo, writer regions, text regions.
You can delete these mentioned regions in header/footer areas too. But you can not copy these regions.
You can not copy to another Smath File's header/footer area, even to Smath calculation area.
Simply you can not copy the information in header/footer area to anywhere.
Regards.
#11 已发布: 2018/11/18 17:33:17
983个赞,共6,866个帖子。
I will try to explain ...
Thanks: I know about those things [header/footer]
In Mathcad, I have included a small RGB logo in either one
but so small, that the visitor who demanded just abandoned.
Just a little rainbow was of no interest either !
Does it work w/o copy/paste ?
Wait and see ...
#12 已发布: 2018/11/20 05:01:56
kadpeter
kadpeter
0个赞,共10个帖子。
I've found an issue in SMath.
I made more SMath document with 100% Windows Custom DPI. Month ago I changed my monitor and I had to change Windows Custom DPI to 125%. Unfortunatelly I can't now print my old documents, because the right side of the documents located on the nonprintable area yet.
I use Windows7, I tested 100%, 125% and 150%.
This screenshot was created with 125% Windows Custom DPI:
Here is a test document:
Test_width.sm (1.97 KiB)已下载 1867 次。
There is an other small issue too. I have to click two times to Print icon in printer selection page if I would like to print. First time nothing happens.
Peter Kaderasz
#13 已发布: 2018/11/20 13:36:46
2,344个赞,共4,057个帖子。
Hello Peter.
Yes, I'm already informed about this issue. Working on it right now.
Sorry for inconvenience.
Davide Carpi 2018/11/20 15:20:00
#14 已发布: 2018/11/25 01:22:29
Jose Carlo Mendoza
Jose Carlo Mendoza
7个赞,共14个帖子。
I have a problem with strings in smath worksheet. It turns out that some characters are converted if input string matches some hexadecimal characters..i don't know if this is a feature..but it transforms some of my smath documents specially with strings as FilePaths..please see attached snapshot.
#15 已发布: 2018/12/11 13:08:00
1,362个赞,共2,276个帖子。
Portable distribution with plugins updated to current stable build (6884). See signature for the link.
4位用户喜欢此帖子
Radovan Omorjan 2018/12/12 08:59:00, Andrey Ivashov 2018/12/12 09:34:00, sergio 2018/12/11 15:17:00, Вячеслав Мезенцев 2018/12/12 08:51:00
