SMath Studio 0.98.6398 (09 July 2017)
SMath Studio 0.98.6398 (09 July 2017) - 消息
#1 已发布: 2017/7/8 19:45:04
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_98_6398.Mono.tar.gz (1.25 MiB)已下载 2748 次。
SMathStudioDesktop.0_98_6398.Setup.msi (2.12 MiB)已下载 5913 次。
8位用户喜欢此帖子
Вячеслав Мезенцев 2017/7/9 01:56:00, Davide Carpi 2017/7/9 03:49:00, NDTM Amarasekera 2017/7/9 05:18:00, Mikaël 2017/7/9 05:19:00, Radovan Omorjan 2017/7/9 06:34:00, sergio 2017/7/9 15:32:00, Martin Kraska 2017/7/9 20:17:00, Василий Николаевич Храмушин 2017/7/10 02:40:00
#2 已发布: 2017/7/9 20:29:48
1,362个赞,共2,276个帖子。
When I try to change the decimal separator in the Options window and press [OK], then I get an error. I can only recover by pressing [Cancel].
SMath Studio: SMath Studio Desktop 0.98.6398.26177, portable, x64
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Windows 7 Professional Service Pack 1, x64)
Screen: 1920x1080 px, 96x96 dpi
Localization: separator=; decimal symbol=; system decimal symbol=; language=ENG
Frameworks: CLR 2.0.50727.8669
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.6.01055
Full 4.6.01055
v4.0
Client 4.0.0.0
显示剧透
#3 已发布: 2017/8/1 09:30:08
1,362个赞,共2,276个帖子。
A new portable distribution with Maxima is available (follow the link in my signature).
Based on an update of the Maxima plugin, it's full set of features is back, including the re-direction of integral, limit and sum functions to Maxima. Due to SMath API changes, this was not possible in the release earlier this year. If you use the Maxima features in SMath, I recommend to upgrade.
The Maxima plugin is not yet easy to configure, therefore I recommend to use the ready-to-run portable distribution.
Best regards, Martin Kraska
SMath without Maxima:
SMath with Maxima:
2位用户喜欢此帖子
sergio 2017/8/1 11:10:00, Davide Carpi 2017/8/1 14:18:00
#4 已发布: 2017/8/12 16:42:41
1,362个赞,共2,276个帖子。
There is a regression in importData. The attached file can't be read correctly. It seems that the decimal separator is ignored at all, no matter to what value it is set.
Rissprobe.txt (695 B)已下载 1300 次。
#5 已发布: 2017/8/14 05:24:06
1,443个赞,共2,936个帖子。
Confirmed, thank you.
