Square root/power of and matrices
Square root/power of and matrices - 消息
#1 已发布: 2017/4/7 04:55:17
mykologen
mykologen
1个赞,共5个帖子。
Hi there!
I am having an issue with a definition witch gives following error: "Cannot calculate"
Please se section under ERROR in attached file. Can't figure out why it wont work... suggestions?
Thanks!
3020-3050.sm (21.41 KiB)已下载 1261 次。
#2 已发布: 2017/4/7 05:20:07
325个赞和1个踩,共2,052个帖子。
Just put the vectorize wherever you find the error. There will be no errors anymore.
mykologen 2017/4/7 06:24:00
#3 已发布: 2017/4/7 06:14:23
mykologen
mykologen
1个赞,共5个帖子。
That does not seem to work, updated my file with my tries... 3020-3050.sm (24.91 KiB)已下载 1199 次。
#4 已发布: 2017/4/7 06:15:44
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
The revised worksheet attached pl.
3020-3050_R1.sm (22.62 KiB)已下载 1346 次。
2位用户喜欢此帖子
mykologen 2017/4/7 06:24:00, Radovan Omorjan 2017/4/7 06:52:00
#5 已发布: 2017/4/7 06:23:58
mykologen
mykologen
1个赞,共5个帖子。
Thanks a lot!
#6 已发布: 2017/4/7 06:54:41
Thanks a lot!
I should have attached the corrected file like ndtma did, sorry.
2位用户喜欢此帖子
mykologen 2017/4/7 06:56:00, NDTM Amarasekera 2017/4/7 08:54:00
#7 已发布: 2017/4/7 08:39:07
983个赞,共6,866个帖子。
Thanks a lot!
In your application, my preference goes for "global vectorize".
It makes easier to manipulate equations.
#8 已发布: 2017/4/8 09:00:54
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Thanks a lot!
Pl look at this.
3020-3050_R2.sm (30.42 KiB)已下载 1270 次。
mykologen 2017/4/10 06:47:00
#9 已发布: 2017/4/9 23:10:35
983个赞,共6,866个帖子。
You are right: this project is not a case for "vectorize".
It makes much easier to read and pass QA [Quality assurance].
3020-3050_R2.sm (24.81 KiB)已下载 1244 次。
